So my truck has been down for about a month now do to some leaks from fuel bowl and HPOP reservoir. Had some shipping issues, but Clay took care of me. So I am now stuck trying to figure out why the top cover is leaking. It was leaking from the right corner bolt so I replaced the gasket, then it started leaking from the 3rd bolt from the right. So, I replaced the gasket again after finding some cuts in it. Well, it is still leaking at the 3rd bolt now and I am going crazy. It is possible that I need to replace the top cover or is there some trick to getting it to stop?
This pick isn't mine, found it through Google. sorry if I offended the owner for using it.
