in a bind need little direction
Old Jan 28, 2014 | 05:48 PM
bcaughhorn's Avatar
bcaughhorn
My 4wd has not worked since I bought my truck. I never was concerned with it until now. I need it some kind of bad.
I read somewhere on here that there is a bolt on the transfer case that I can. Turn with a 9/16 I believe. Can somebody tell me which bolt? What side?
Old Jan 28, 2014 | 06:02 PM
Christof13T's Avatar
Christof13T
The "bolt" is the selector stem that the shifter motor is hiding.
Pull the shifter motor... then look up where it was and you will see the doo dad you need to put a wrench on...
Old Jan 28, 2014 | 06:23 PM
Bobbykjl's Avatar
Bobbykjl
I'm not aware of a manual override. Can you diagnose the switch to the electric motor.
There is a relay activated by the 4x4 switch. Did you check fuses and the transfer case shift motor relay? Are you getting 12 volts to the xfer case motor when turning the switch. You can disconnect the connector and put a test light on and turn the switch from 2H to 4H and see if you have power.
possible problems
1. Xfer case shift motor
2. Dash switch
3. Relay
4. Fuse
5. broken wire
6. GEM or PCM
Old Jan 28, 2014 | 06:25 PM
Bobbykjl's Avatar
Bobbykjl
aha, there is an override. Thanks
Old Jan 28, 2014 | 06:30 PM
bcaughhorn's Avatar
bcaughhorn
I've checked the switch and the relay from what I've read on here. Both are working right. I've just never made it to the selector. Now I'm kicking my self in the ace
Skydivelout
18
Feb 1, 2020 06:00 PM
pmrfin
Oct 30, 2014 11:44 PM
Jimbo06
Jul 18, 2011 05:01 PM
Ron Mantz
Dec 16, 2009 07:42 AM
Finally
Mar 23, 2006 07:12 PM
