Can someone help me with my 1950 F1 VIN identification?
Old 01-28-2014, 04:39 PM
Thbifeb's Avatar
Thbifeb
Thbifeb is offline
I have been searching for how to identify my 1950 Ford F1 and I can't seem to find the thread. I thought I read where you could identify the original color.
My VIN is 97HC 321410 CH
If anyone can help me identify any part of my VIN I would greatly appreciate it.
Thanks
Thbifeb
Old 01-28-2014, 04:47 PM
mwarner1948's Avatar
mwarner1948
mwarner1948 is offline
97HC 321410 CH
9=49-50
7H=226 ci 6cyl
c=1/2 ton
321410=production series
CH (no idea)
Old 01-28-2014, 04:50 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Hey Thbifeb
The firewall stamping / stencil is the only guide for the older years for color or assembly plant. The VIN breakout is as mwarner shows.
DW
Old 01-28-2014, 05:20 PM
Doc's Avatar
Doc
Doc is offline
Originally Posted by FortyNiner
Hey Thbifeb
DW
I've discovered that a lot (but definitely not all) of the VIN numbers will have the assembly plant stamped at the end on the firewall tag. For instance, a lot of the Louisville trucks have LOU stamped after the VIN. In this case, the "CH" could very well mean the Chicago factory? That VIN number sequence is well within the 1950 range.
EDIT: Here's the legendary multi-year thread that will teach you more than you ever want to know about deciphering those VIN's and firewall stampings. https://www.ford-trucks.com/forums/4...n-cut-off.html
Old 01-28-2014, 09:36 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
CH is Chicago.
Old 01-29-2014, 08:31 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 51PanelMan
CH is Chicago thru 1952.
G = Chicago: 1953 thru today.
MERCTRUCKMAN
01-21-2015 04:03 PM
IslandGirl
68
06-08-2012 12:18 PM
87Mater
04-24-2010 10:34 PM
bryanknie
06-11-2002 02:13 PM
skeleton
08-11-2001 09:09 PM
Quick Reply: Can someone help me with my 1950 F1 VIN identification?
