94 f250, removed and cleaned the multifunction switch which fixed my turn signal issues, now any time the door is opened the Chimer goes off, iirc it only did this before if the lights were on but there not, any ideas/sugestions
Check your ignition Switch Mine does it when the Ignition switch is turned to far back and the truck seems to think the key is still in. I just twist it forward some and it stops.
Just remove the ground attached under the shroud of the steering wheel. The buzz will never happen again.
+1. Pull the ignition lock cylinder (takes less than 10 seconds with keys), and disconnect the wire from the key sensor. End of annoyance, and the headlight warning chime will still work as usual.
