Trans vacumn lines ????
Old Jan 26, 2014 | 06:37 PM
Scoop531's Avatar
Scoop531
Noticed there are 2 metal lines at fire wall coming up. One has nothing one has a line but is unplugged are both suppose to be plugged in and to where
Running a c6 351m with performer RPM intake and edlebrock carb
Old Jan 26, 2014 | 06:49 PM
gatorfor88's Avatar
gatorfor88
one is modulater valve vacuum. my 78 351m has a vacuum fitting on rear of manifold with about 4 differentports in it where mine goes. the other one I dont know. trace it back to where it goes
Old Jan 26, 2014 | 07:14 PM
Don Senkow's Avatar
Don Senkow
Below find a very good explanation. You need a line running from the intake manifold to the rear of the modulator. The other line plugs into the side of the modulator and into the EGR system. if the transmission shifts OK, I would not worry about it.
Q. Why does my 73 model C6 modulator have two vacuum hoses?
A. 73 was the first year for EGR valves. It was found that when the EGR opened, intake vacuum dropped causing later shifts. Adding the inner vacuum line which comes from the EGR, helped rebalance the shift points. Normally the inner (smaller) vacuum hose can be plugged off and the port on the modulator left open with no ill effects.
Old Jan 26, 2014 | 08:13 PM
Scoop531's Avatar
Scoop531
I see. Well all the egr stuff is long gone nowi haven't drive. It since intake was installed by PO I am finishing his halfway complete project
jaleus
Feb 15, 2017 09:33 PM
JOgle1185
1983 - 2012 Ranger & B-Series
Jul 5, 2007 01:20 AM
eigenvector
Sep 5, 2006 07:49 PM
crawdad
Apr 5, 2006 10:45 PM
compaddict
Jul 21, 2005 08:43 PM
