Help on Rear Springs & Shackels
Old 10-17-2013, 02:03 PM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
HELP
I bought a set of 3" rear springs & shackle kit for my 52 F-1.
When I go to bolt up the rear of the spring with the shackle the shackle bolt is not long enough to attach to the original inside mount.
There is nothing to support the inside of the upper shackle bolt.
Suggestions???
Thanks,
Tractormanbill
Old 10-17-2013, 02:43 PM
tractormanbill
tractorman
Got the answer to Speedway Motors.
They do not have a shackle to fit the 52 F-1 you are supposed to use the original cast shackle.
Sorry for the thread.
Tractormanbill
Old 10-17-2013, 02:58 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
What springs is that? Posies?
Old 10-17-2013, 03:08 PM
tractormanbill
tractorman
I believe Posies' is correct.
Speedway was not supposed to send me these 2" shackles.
I had about decided to use the original cast shackles anyway.
Tractormanbill
Old 01-25-2014, 01:30 PM
DougofMontana's Avatar
DougofMontana
DougofMontana is offline
Can one of you tell me the secret to getting the shackle pins out of the front mounts for the rear springs? I'm mystified!
Old 01-25-2014, 08:20 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Old 01-25-2014, 09:14 PM
DougofMontana
Hi Stu, I got impatient this evening and simply ground off the four rivets on the outside and used a little wedge to pursuade the mounts off the frame. I had considered using the puller technique, but didn't have the proper sized bolt around and seeing as how I live 12ish miles from town I wasn't making the drive. When I go to remount these, I'll be sure to use grade 8 bolts! I looked at the pins compared to the pins show I that thread you gave me the link for and mine look like new compared to those. After taking the steering linkage apart and not seeing ANY wear there, I'm about half convinced that the mileage showing on the speedometer is actual mileage (27,400 miles) I know for a fact the PO owned the truck from 1965 until last August and he never took it off his 50 acre horse ranch. Thanks again for the idea about the puller!
Old 01-26-2014, 12:42 AM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
There is a hole on the inside of the frame, the pins can be driven out with a long pin punch.
Old 01-26-2014, 08:18 AM
DougofMontana
Aussie, the hole for the front pin is blocked by a brace for the cross member, so no hole . I've heard where some guys get under and drill a hole in the brace to gain access, but my way worked.
Old 01-26-2014, 08:22 AM
Doc's Avatar
Doc
Doc is offline
Ford basically "forgot" to drill an access hole in that crossmember so that pin could be driven out. They corrected the oversight in later models. For future reference, you can take about a 3/4 to 1 inch hole saw and cut your own access hole in a matter of seconds.
Old 01-26-2014, 09:09 AM
truckdog62563
Or did Ford provide dealers a shop tool, as did Dodge, to pull the pins without the drama of swinging a hammer under a customer's vehicle? IMHO it makes no sense to drive the pins out when it's so simple to pull them. Besides, Henry was all about saving time on a job which the puller accomplishes. Stu
Old 01-26-2014, 09:49 AM
Doc's Avatar
Doc
Doc is offline
Good point. Wouldn't you like to have a time machine, travel back to a Ford garage from 60 years ago, and steal one of their toolboxes containing all those specialty tools we see in the manuals, among many other things......
Maltman
12-02-2018 06:21 PM
capelo
10-27-2013 05:21 PM
4EyedTurd
07-03-2012 10:47 AM
tjdad62
12-14-2010 09:57 AM
thunder31634
10-12-2010 06:01 PM
Quick Reply: Help on Rear Springs & Shackels
