1960 Magic Air Control ?
Old 01-27-2014, 10:34 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
So I have been dealing with a guy about some heater parts that he needs. He has told me that he is looking for a 59/60 magic air control. The part I have a question about is he says he has been told that the 59/60 control is suppose to have a siver face in the center, a silver plate around that and then the chome housing. I dont ever remember seeing the face anything other than black. I have one with a black face and silver surround with black *****. I also have one with a black face with a white surround and white *****. Does anyone have or have seen one of these controls with the silver face? I seen a picture of it but it looked like faded black to me. I asked Stu to look in his master fridge parts book and it didnt show much, and I looked in mine and came up with only one part number and it said nothing about face color.
Old 01-27-2014, 11:13 AM
mcdonaldm's Avatar
mcdonaldm
mcdonaldm is offline
the one i took out of my 59 truck is silver faced and i think it was silver or grey surround. i would have to see if i could find it as i didn't re-use it on my build as i didn't put a heater back in. strictly a summer cruising truck.
Rgds
mike
Old 01-28-2014, 09:53 AM
real550A's Avatar
real550A
real550A is offline
This is the control in my one owner '59 F350, clearly a black face. That said, if anyone has one to sell, or the parts to repair mine, please PM me! The bottom cable lever is broken off right behind the face, and broken part & **** missing.
Old 01-28-2014, 05:38 PM
real550A's Avatar
real550A
real550A is offline
As I was removing the heater control from the dash, the broken piece of the bottom lever fell out. Next, I dropped the push nut that holds the top cable on, and it landed in between the shifter and the floor mat. While retrieving the nut, I found the **** for the bottom lever. My lucky day! That bottom lever is secured by a piece of thin sheet metal. Designed to fail?
Old 01-28-2014, 06:14 PM
real550A's Avatar
real550A
real550A is offline
I see that the broken piece is spring steel, designed to hold the lever down in the slot adjacent to the "heat" setting. It still seems flimsy when you know those cables aren't going to glide easily forever!
Old 01-28-2014, 06:16 PM
spurredon's Avatar
spurredon
spurredon is offline
I had to repair mine as well. Lube up your cables good and you should be all set.
Old 01-28-2014, 07:36 PM
real550A's Avatar
real550A
real550A is offline
Spur- What material did you use? The original is spring steel, but I was thinking of something like 3/32nds aluminum or something a little more rigid.
Old 01-28-2014, 08:08 PM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
Wish my 59 had the original controls like that... That's pretty sweet! Ill have to be searching for aftermarket options. Because I like AC lol
Old 01-29-2014, 06:13 PM
spurredon's Avatar
spurredon
I think I used a piece of steel banding, you know, like what wraps up large commercial type boxes or to hold things on pallets!
Old 01-29-2014, 08:26 PM
real550A's Avatar
real550A
real550A is offline
Thanks spur- I found a piece of stainless in the scrap barrel that worked out well. Got the control lubed up and working like new.
Old 01-30-2014, 09:01 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
COTF-18549-B (replaced B3A-18549-A) .. Control Assembly-Fresh Air Heater / Obsolete
Applications: 1957/60 F100/1100 / 1952/53 Ford Passenger Cars.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
KLIMESH MOTOR SALES in Calmar IA has 1 = 563-562-3241.
firstrider
21
06-12-2015 09:19 PM
F-100CustomCabTBC
30
02-23-2013 06:51 PM
fireball14513
01-25-2012 04:12 PM
hatemakings/n
Garage & Workshop
33
07-13-2005 12:43 AM
mr4speedford
06-20-2003 03:02 PM
Quick Reply: 1960 Magic Air Control ?
