rough Idle and vibration in steering wheel
hello I have been having this problem with Gf's car for a few months it is a 06 3.0 escape with 141K on the clock the car seems to run ok except at red lights and when in drive it seems to idle like its just about 100 rpms low when I give it a little gas just a touch it smooth's out. if I put it in neutral the car smooth's out but in drive when you come to a stop light or stop sign you can feel the rough or low idle in the steering wheel. She is nagging me and it has been very cold here in Pa and I'm trying to wrap my head around if it is a cold thing or just a coincidence. I'm fairly good at wrenching and I just need some things to look for as when you start the car up cold it idles fast like 12 to 1300 rpms and then drops to about 900 and in drive it seems like maybe it's about 600 to 700 rpms. but I'm needing some advice where to start to look Is it a sensor, vacuum leak ? anyone else have this problem and what was the solution. Thanks for any help in advance.
plugs were new at 100k,fuel filter is good ,air filter is good. Now that you mention it could it be the mounts? as in warm weather there is more give and in cold weather they are stiffer, or at 141 they might just be worn out has anyone else changed mounts at this mileage on the clock?
countrysF250
11-20-2014 04:01 PM
invaderc
Escape & Escape Hybrid
04-25-2012 07:56 AM
