6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
#8 cylinder knock
Old 01-24-2014, 10:43 AM
captain_trucks's Avatar
captain_trucks
captain_trucks is offline
#8 cylinder knock
Hello
I have an 08 with the 6.4L. I have a knock that nobody can find. It has been doing it for about 15,000 miles. The engine has 200,000 on it now. It is the #8. Engine runs like a top, nice and smooth. All drivers side injectors are new, heads have been off, new lifters and rockers installed. I have no codes. The #8 does have low contribution but not low enough to toss a code. I am getting very tires of the noise and I believe it is getting worse, but it does sometimes almost go away. Very frustrated. Any ideas??
Thanks
Old 01-24-2014, 08:42 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Does the knock speed up with rpms?
Old 01-25-2014, 06:13 AM
captain_trucks
Yes, gets quieter with rpm though
Old 01-25-2014, 07:31 PM
9228.bobcat
When let off going down the road at about 55 or 60 can you here it ?
Old 01-25-2014, 08:54 PM
GSchretter's Avatar
GSchretter
GSchretter is offline
Have you not checked the cam or crank shaft bearings?
Old 01-26-2014, 11:50 AM
captain_trucks
No, it sounds normal when u let off?
Cam bearings are good. Noise is defiantly top end.
Old 01-26-2014, 12:57 PM
9228.bobcat
And you checked all your injectors? Maybe a rocker arm.
Old 01-27-2014, 06:28 AM
captain_trucks
New injectors and new rockers and new lifters as stated in the beggining. The noise can be heard with a stethascope right at number 8 cylinder at the exhaust manifold.
Old 01-27-2014, 10:29 PM
9228.bobcat
Yea I seen that but didnt know how long ago it was replaced, mileage wise. Them rockers are kind of weak.
sudsmcduff
01-12-2016 06:24 AM
Whisker
16
11-17-2012 11:29 PM
JockD
10-22-2008 07:34 PM
joedots
11-19-2003 02:32 AM
Quick Reply: #8 cylinder knock
