2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Need Brake Help
Old 01-17-2014, 06:01 PM
Tri865's Avatar
Tri865
Tri865 is offline
Need Brake Help
Hello new to site. I need some help. I own a 2010 Expedition 4WD with 29,000 miles on it. My right front brake is hanging up. I have completed the following repairs, both rotors turned(less than 29,000 miles on vehicle), caliper (replaced twice on right side), new caliper mount, 2 new brake hoses on front, new brake shoes each time, brake fluid completely flushed, power bleed brake system. The right front brake pads are only making contact on the upper inch portion of the rotor and are dragging. The rest of the brakes are fine and the brake pad contacts the full width of each rotor. I can turn the wheel its not locked up. The rim get hot to the touch the rotor is really hot with brake smell. I dont know what else to do next.
Old 01-20-2014, 05:47 PM
berry1234's Avatar
berry1234
berry1234 is offline
Sounds like something is bent. I would take it to a shop you trust.
Old 01-20-2014, 10:58 PM
bunky383's Avatar
bunky383
bunky383 is offline
did you check your wheel bearings?
Old 01-22-2014, 04:08 PM
Tri865's Avatar
Tri865
Tri865 is offline
Yep, bearings seem fine, the hub is cooler to the touch then the rotor, no grinding or whining from the hub.. The caliper and the rotor are getting hot. Hard to tell how much because its 10 degrees here. Someone told me the brake pads might have a high spot on them. I'm going to take them off this weekend and see how level they are, maybe put the old worn ones back in and see.
kincfu
03-20-2016 08:43 PM
TJK1
08-05-2013 02:36 PM
arkredneck
11-03-2011 03:28 PM
welder1985
05-10-2009 01:48 PM
gordo777
10-26-2005 04:17 PM
Quick Reply: Need Brake Help
