Oil change first and a couple questions
Old 01-25-2014, 05:34 PM
mjunk1's Avatar
mjunk1
mjunk1 is offline
I was changing the oil today and the Motorcraft filter I got, the FL1995, had bad threads. It would spin about 1.5 turns and then stop. I figured I better not force it (ah ha! I actually have learned something after all these years!) and went back and got another one. It spun right on no problem. I don't think I've ever had a filter with buggered threads before.
Also, my truck takes a full 16 quarts if you change the filter. I thought it was only 14 - am I crazy or just wrong in my thinking.
Finally, I seem to have a leak near the steering shaft/PS lines. There seem to be two fuel lines there also and I am thinking they are the issue. When I change out to the efuel set up, will those couples go away? You can see them from the inner wheel well, just above the steering shaft and below the PS pump.
Old 01-25-2014, 05:36 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Are you positive the leak is from one of the fuel lines?
Old 01-25-2014, 06:10 PM
mjunk1's Avatar
mjunk1
mjunk1 is offline
No, but it is definitely soggy over there. Just too cold to try to figure out. Could bethe return line for the ps pump. I ddnt replace that one when i did the pump.
Old 01-25-2014, 06:14 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I was thinking maybe the power steering. It's pretty common to be wet around there.
Old 01-25-2014, 08:23 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
I've seen buffers threads before Dan, it's definatly inconvenient. Glad you got that resolved! 15 qts seems to be the norm with mine. Although I've only done the oil change twice since I've had the truck.
Old 01-25-2014, 08:50 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
15 quarts for mine and I run the oil by pass system also. Anyway, you gave me a laugh. You stopped and listened to yourself?? LOL Took me over half my life to learn that trick Dan!
Old 01-25-2014, 09:32 PM
tshrager's Avatar
tshrager
tshrager is offline
I'm a little over 15 when I run the big Donaldson filter. 14 when it's a Motorcraft filter.
Old 01-25-2014, 09:38 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
It is only 14 quarts. You dipstick is wrong
Old 01-26-2014, 05:21 AM
427 fordman's Avatar
427 fordman
427 fordman is offline
Mine's actually 14.5 for what its worth. That is just the pan and filter.
Always check the filters before you put them on. I've seen buggered threads, metal shavings in the threads, etc.
Old 01-26-2014, 09:25 AM
fordman67's Avatar
fordman67
fordman67 is offline
14 Is the correct amount. Don't fill to the top of the stick.that's too much.the 14 theoretically should put the level in the middle of the stick.imho you are over filled.
we used to have stupid customers argue with us about us ripping them off at the dealership..we knew how much vehicles required..but they wanted them "full" except that was over full..some people..ugh
now this leak..is it leaking on the ground? what color is. it? It could be fuel,ps,or oil from rail plugs,hpop res,or fuel return line at the front of the head..yea its cold...i can't get motivated either!!!
Old 01-26-2014, 04:32 PM
richdawg's Avatar
richdawg
richdawg is offline
My 02:
15qts is the amount with a filter change. (if you fill the filter) recommended
The HPOP reservoir and HPO rails don't figure into the change capacity.
If you don't start it and let it circulate, the figure will read high.
Makes sense to me, there are some variables though, the area where you change must be level and I use the donaldson which adds about another quart.
I change my oil once a year, weather it need it or not. I only drive it 2000 - 3000 a year.
Old 01-26-2014, 09:15 PM
mjunk1's Avatar
mjunk1
mjunk1 is offline
That is what i thought but i ran it after the change and it was at the low mark on the stick. It took 2 more quarts, so a full 4 gallons. I guess i could have the wrong dipstick. I'd hate to be the guy with the "little dipstick". Lol....how would i live that down? At least i did have 5 kids!!!!
Old 01-26-2014, 09:18 PM
fordman67's Avatar
fordman67
Yea..14 with the fl1995. That donaldson holds more than the standard filter.
Old 01-26-2014, 09:24 PM
mjunk1's Avatar
mjunk1
mjunk1 is offline
So can someone measure the length of the dipstick? Mine must be short but i would like to be sure.
Old 01-26-2014, 11:11 PM
fordman67's Avatar
fordman67
I can.also check the dipstick seal inside the handle.mine was dislodged and on the tube.if yours is wadded up in the bottom of the handle it would hold the stick out thus making u need more oil than really needed.just a thought
Quick Reply: Oil change first and a couple questions
