Clearance lights parts inquiry
Thanks for the replies guys,
I bought a set from LMC a year or 2 ago. I didn't like them so isold them on Ebay. the problemwas the factory pigs tails would not fit the twist lock socket on the lens. while they did supply new pig tail wiring, the wiring would not plug into the factory harness. And I didn't want to splice it all up for the next owner. Then I would become one of those dreaded PO's. Any way I'm kinda leary of NPD for the same reason, through possibly unwarranted.
I screwggled the part number as well, yep 8 in 5 locations, 2,2,2,1,1. I guess thats the way to go. Wished one of them had a full set.
Again thanks to all of you
Never too late on this project Mike, it's Been going for like eight years.
So I have been digging around and found another part number for what looks like the same lens.
E0TZ 15442 E. Looks an awful like the D6TZ 15442 A.
I think the E0TZ 15442 E uses the same D6TZ 15442 B pig tail. If the mounting screw spacing is the same, then what's the diff . Change in gasket material?
After I posted the pictures, I'm thinking its the color??
robles4242
09-19-2010 10:28 PM
