Carr is the brand, i have them on my 77, they are solidly built.......They were added by a previous owner. For whatever reason, the picture isnt loading. they drop down maybe 5 or 6 inches below the door, and are just wide enough to fit a big heavy workboot. assuming they are still made, they likely would work for your application.....
Iam in the same boat but I have a 79 crew cab that I would like to put a step on but not finding much on the net, the way it sounds I might have to fab some up, but would like to see some pictures of some other before jumping into it.
I went with the DeeZee diamond plate steps, they mount to the frame. They don't make them for 73-79 style anymore, but I was able to adapt the ones from a late model Ford
I would think so, the mounting point seems to rotate to accommodate different vehicles.....if nothing else, you could cut a piece of 1-1/2 to 2", angle iron or square tube and combined with this step, fine tune it for your application.
