Radiator support
The 78-79 supports have different bolt hole paterns for the head light buckets. They can be interchanged but drilling is require to make it work.
Also the 6 cylinders have a smaller rediator hole opening than the V8's. Somne guys will cut the opening bigger to use the V8 radiator. BUt once the hole is cut bigger the 6 cylinder rad doesn't have any mountionmg hole to bolt to.
To really get the right fit you need a 6 cylinder radiator support from 73-77.
79f100six
10-17-2007 09:21 PM
DAV1972
08-14-2007 10:05 AM
