1949 F4 Fender Turn Signal
Old 04-05-2024, 07:22 PM
BBF4's Avatar
BBF4
BBF4 is offline
Here is the turn signal on my front fenders. I took them apart to change bulbs and I realized the gaskets are deteriated and some places non existant. Is there a source for gaskets or is it time for new lights?
Old 04-05-2024, 07:51 PM
bmoran4's Avatar
bmoran4
bmoran4 is online now
Those are not factory. Many trucks have had similar fender indicator accessories added. I would measure the lens diameter (4"?) and find a generic gasket of appropriate size.
The following users liked this post:
Old 04-05-2024, 07:52 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
They can be cleaned up or you could probably find nicer old ones on eBay. When I was fixing up my 55 F350 I found decent Dietz lamps on eBay. I cleaned them up. Painted the outside black. I painted the inside white. There was a discussion here about that. We discovered that white on the backs reflected more light than silver.
They needed gaskets. I called Dietz. They did not have any. The guy said I should cut gaskets out of thick cardboard like the cardboard on the backs of school tablets. They didn't work the greatest. So I had an idea. I went to a hardware store that sold canning supplies. I bought the rubber rings that seal mason jars. I had to trim them as the outside diameter was a bit too large.
The following 2 users liked this post by abe:
Old 04-05-2024, 08:12 PM
abe's Avatar
abe
abe is offline
Here are some pics of the turn signals on my F350:
This is the old ones.
I put a double filament socket in them. They came on when the parking lights were turned on. this style of turn signal lamps are called drum lamps due to their resembling a drum.
I bought stainless screws to replace the rusty original ones. And I did buy NOS lenses.
Old 04-05-2024, 08:15 PM
abe's Avatar
abe
abe is offline
As far as I know, no fender turn signal lamps were factory, all aftermarket.
Old 04-05-2024, 08:37 PM
abe's Avatar
abe
abe is offline
Look at these BBF4, NOS Signal Stat
https://www.ebay.com/itm/32606758851...Bk9SR5ydn5DWYw
After looking at mine maybe mine were Signal Stats.
Old 04-05-2024, 08:40 PM
BBF4's Avatar
BBF4
BBF4 is offline
A little out of my price range!
Old 04-05-2024, 08:49 PM
bmoran4's Avatar
bmoran4
Current and inexpensive. Will need to swap in some 6V bulbs: https://www.tractorsupply.com/tsc/pr...and-turn-light
Old 04-05-2024, 08:54 PM
abe's Avatar
abe
abe is offline
Understood.
Keep looking on eBay. You might find good used ones. Or clean yours up.
Old 04-05-2024, 09:39 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
They look to be in good enough shape to clean up and use. I can't see the other 3 lenses, but if nothing looks worse than we see here, I'd restore them enough to keep using. They're period correct and have a patina that looks like they belong there. If the lenses need a gasket, some thin sheet cork and an exact-o knife should be able to handle that.
The following 2 users liked this post by 52 Merc:
Old 04-07-2024, 07:31 PM
52Flthed's Avatar
52Flthed
52Flthed is offline
Abe, Those NOS signal Stats were a great price. Look like an earlier version too. What I like about them is they are exactly the same size and look exactly like the Dietz made FoMoCo accessories from 51-52 trucks. Honestly the Signal Stats are actually better, easier to change bulbs and find and find parts for.
BBF4, - Get some gasket sheet material, Cork and Rubber combo and just cut your own gaskets out of that. Just a thin gasket sheet is all you need if you want to re-use them. 99% percent of the time these old trucks had Aftermarket turn signals of one make or the other. Signal Stat was probably the most popular Yankee and Teleoptic as well. There were several good manufacturers. Personally I like the earlier ones with the arrow shapes cut out in them.
Old 04-07-2024, 08:26 PM
abe's Avatar
abe
abe is offline
Agreed.
Those are really old, aren't they.
Old 04-07-2024, 08:50 PM
52Flthed's Avatar
52Flthed
52Flthed is offline
Abe. From what Ive known and seen, and judging from the box graphics they look to be from the very late forties or more likely early to mid fifties. The earlier fender signals from 30s, 40's tend to use an arrow shape cut out in the lens. Even Ford's Factory turn signals went from "arrows" in 48-50 and then changed to yellow/red- front/rear, full lens in 51-52. I have a pair of NOS Signal Stat units just like this listing only mine are in a box with tell- tale 60's even 70's graphic style on it. They made this style for decades.
I still have the older arrow style Signal Stat units on my trucks fenders. From photos I know they've been on the truck since at least the 80's so I left them on, also I like them better.
The following 2 users liked this post by 52Flthed:
Old 04-08-2024, 12:49 PM
DieselDog409's Avatar
DieselDog409
DieselDog409 is offline
"Clears Thought"...
Ima' just leave this here
dlpartyka
04-05-2022 02:14 PM
Tomagnor
21
12-25-2021 03:47 PM
Highwayman7043
05-29-2018 08:24 PM
chrissmallwood
Large Truck
04-21-2016 06:37 PM
PRO49FORD
09-08-2015 09:15 PM
Quick Reply: 1949 F4 Fender Turn Signal
