95 aerostar 3.0 vacuum housing and diagram - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Reload this Page >
Aerostar Ford Aerostar
Old 01-19-2014, 01:53 PM
jim33067
jim33067 is offline
jim33067 is starting off with a positive reputation.
This has drove me nuts. Im trying to figure out if all my vacuum hoses are hooked up to my vacuum tree. I have 2 nipples on the tree with no hoses and I had to use caps, not sure if a cap was on there before and finally fell off or if there is a hose that went there. I can never find a good photo to show where the hoses go from the main vacuum tree which is right next to the distributed. Does anyone have photos, a website, diagram or any info on this??
Old 01-20-2014, 05:03 PM
formeat
formeat is offline
formeat is starting off with a positive reputation.
The hoses on a 3.0L vacuum tree lead to the:
1) Brake Booster (located on the drivers side)
2) PCV valve (located at the rear of the drivers side valve cover)
3) Fuel Pressure Regulator
4) Vacuum Reservoir/Climate Controls (a very narrow white plastic hose similar to that used on the window washer system). The hose leads into a rubber adapter that attaches to one of the nipples on the vacuum tree.
5) Vacuum Modulator (older model Aerostars only) - Located on the transmission
Cap off any unused hose connections on the vacuum tree. Most auto parts stores sell a multipack with various size plugs. Insure that every hose and plug is securely connected. A backfire can easily cause any of the hoses or caps to blow right off of the vacuum tree. Use small hose clamps on them where necessary.
Old 01-20-2014, 06:06 PM
jim33067
jim33067 is offline
Thank you for the response!
Old 01-20-2014, 08:49 PM
Mikeman
Mikeman is offline
Mikeman is starting off with a positive reputation.
I think there might be a few more vacuum connections:
EGR (if you have one, my '95 4.0 didn't but my '97 3.0 does)
cruise control
evap system
The EVTM doesn't show all the vacuum connections, which is disappointing. There might be something else that's missing.
Old 01-21-2014, 10:16 AM
DFord
DFord is offline
DFord is starting off with a positive reputation.
Does this help?
Old 01-21-2014, 07:51 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
they come from the factory with a vacuum line diagram on the frame above the radiator or on the underside of the hood.
| Repair Guides | Vacuum Diagrams | Vacuum Diagrams | AutoZone.com
hharris8
27
08-02-2016 05:02 PM
grandpas1974
04-08-2016 11:34 AM
78 & 87 Super Cab
11-07-2013 12:44 PM
Oldbone
05-07-2012 04:05 PM
bloodspoint
09-29-2010 04:22 PM
Quick Reply: 95 aerostar 3.0 vacuum housing and diagram
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
