bronco fuel tank?
bronco fuel tank?
56 f 100
351c
C4
Jag rear end
Tank inside the cab
I'm going through the process of making my truck mine.
Working on the tilt nose now, but once that is done I'm going to start on the interior. Long story short I want the tank out.
I know the mustang tank fits. But what about a 90/91 bronco tank? It's 32 gallons
351c
C4
Jag rear end
Tank inside the cab
Do a user search for the late RandyJack. He did an amazing job of installing a big Bronco tank in his 56. I'm not sure if it was specifically a 90/91 Bronco tank but it was a full sized tank.
The main things to keep in mind when searching for a tank its size, fuel inlet, and fuel sender. Where do you want the fuel inlet to be? I think the big Bronco tank the inlet will come out towards the driver side of your truck. What kind of gauges are your running? its good to have a fuel sender that will work with your gauges.
I chose a bib Blazer/Suburban tank for my 49. I think its a 38 gallon (they also came in a 24 gallon size) and the fuel inlet goes out towards the passenger side.
Bobby
I was wrong, its an older Bronco tank (1978) but here's a link to his gallery for some pics
https://www.ford-trucks.com/user_gal...&albumid=24084
Bobby
oldhalftons
04-12-2005 10:33 PM
adrianlovessnow
12-01-2003 09:01 PM
