I have a 56 with a 351 cleveland about to go back in. I was wondering if anyone is running headers other than sanderson? I'm having a hard time finding all the measurements to determine if they will fit in there without issues.
I want to change them out because all the non-car people I show off to say - "it's all rusty" - drives me crazy - shiny crazy custom made up truck & all they see is the darn cast iron header
Keep us posted on what you end up doing. I'm thinking about changing my cast iron manifold out too.
I used 71 mustang mach 1 headers on my 54 f100. they fit fairly tight to the block but were not hard to install. I have transdapt motor mounts and had to grind 1/8 " off them to clear the bottom tubes. I also had to cut a 1/4" notch in the passenger side header exhaust extension flange to clear the transmission oil pan.they are also close to the frame mount brake master cylinder and power brake unit. I used hedman s-bend style universal exhaust extension - they make it much easier to line up your pipes. I would recommend using header wrap on at least the lower pipes to keep heat off the brake unit, the starter, and transmission pan.
dale
Before you toss out the iron mani's, try coating them with this. Brush it on and let it bake in. Works good, looks good.
dale
I bought a pair of 351C 4 barrel headers at a swap meet but haven't tried to install them. Their pretty banged up and they were cheap but the seller didn't know who made them. Thought I might be able to make them work when the time comes.
I installed Sanderson's huggers on my 351w and it was really tight with the Toyota box. I have the engine dead center in the frame and there's not much clearance on either side but they do work.
But do not use the wifes oven to bake them . Trust me on this one !!!! Her's was new , I bought it for her ,so I figured some rights to use it were came with it . WRONG!!!
