Info on f750
You should check the large truck section of the forums HERE for more info. This is what I get from the vin you posted.
Decoding: F75FUC99672
Digit Usage VIN Decoded
1-3 Series F75 F750
4 Engine F Unknown!
5 Plant U Louisville KY
6-8 Mod Yr/Mfg Date C99 1976 (Mfg Jul 1976)
6-11 Sequential Serial # C99672 C99672
Serial numbers are sequential per plant
I think you may have typed the vin incorrectly or the decoder I used was inaccurate. This says it is 1976
1-3 Series F75 F750
4 Engine F Unknown!
1-3 Series F75 F750
4 Engine F Unknown!
1-3 Series F75 F750
4 Engine F Unknown!
"F" Digit was 391 4V gas OR 785 c.i. Cummins V8E-235 Diesel.
C00,001 through D82,000 was 1968 model year.
Thanks for your help I have had trouble finding any info on this truck. I was hoping to find a weight but there is nothing on line about weight or haul weight. I think it is a ten ton dump truck but not for sure it was a Knoxville tn gov truck. I bought it to use on farm but motor was locked up so I am doing a transplant, it had a 391 in it I am putting a 390 in it now should be done this weekend I am hoping anyway. Thanks for all your input would put pictures but don't know how
corndogia156
12-27-2022 05:37 PM
