6.0 blues
Old Jan 15, 2014 | 10:33 PM
dweillie's Avatar
dweillie
6.0 blues
ok here goes.....new member but have been reading this forum for a couple years and I think its the best one around.
thinking I had a one in a million luck streak with the 6.0, I now have the issues common to it with some exceptions.
history on it, 2007 f250 6.0 128k miles, regular oil changes, oasis report on hand to verify, never had a issue until two days ago
on the highway at 70mph, heard a ticking sound from engine bay, went away, approx. 1/2 mile later running rough and began white out exhaust. exited and called a tow. it is in fact smoke with diesel smell out of tailpipe. don't have software to diagnose so used a lot of info from here to start out. ruled out head gasket due to clean oil,coolant and in fact white smoke. no one local to test injectors, so I have them sent out. pulled egr/oil cooler and flow testing shows they are still good, also voltage at ficm is good. so,.......hopefully someone has had this experience and can shed light. no hydrolocking, compression is fine across the board. runs rough upon start up and smokes. hopefully this is enough info and thank you in advance
Old Jan 15, 2014 | 10:40 PM
bismic's Avatar
bismic
codes ?
Old Jan 15, 2014 | 10:58 PM
mustang_309's Avatar
mustang_309
Typically when you have a head gasket go on these engines there is no cross contamination of the fluids, that is to say no coolant in the oil, the signs of bad head gaskets is almost exclusively puking coolant from the degas bottle, this is due to the fact that the combustion chamber pressures are so much greater than that of the cooling system that you have gases of combustion passing the sealing surface of the head gaskets into the cooling system where the coolant pressure isn't high enough to do the same.
You would be well served to get yourself some gauges that read live data, like the scan gauge II or one of the smartphone apps like dashboss for IOS devices or torque pro for android.
Old Jan 15, 2014 | 11:06 PM
dweillie's Avatar
dweillie
no puking, no bubbling etc.....and yes I need to get the software, all I have is all my old crap from my 7.3 and no cel or codes are showing
Old Jan 16, 2014 | 04:27 PM
dweillie's Avatar
dweillie
update.......found bent pushrod on #6 valves seem fine, so gunna drop in a new one turn by hand and hope for the best
Old Jan 16, 2014 | 04:48 PM
Bonanza35's Avatar
Bonanza35
Keep us posted please.
Old Jan 16, 2014 | 06:30 PM
mustang_309
Glad you found the problem and thank you for the update.
Old Jan 20, 2014 | 04:46 PM
dweillie's Avatar
dweillie
turns out to be worst case scenario, lifter locked in bore and cant pull it. so with having to pull motor and rebuild I located a local guy with a LOW mileage 03 complete motor running in wrecked 250 with all service docs. I do believe if memory serves that some sensor locations were changed along the production years so if I snag the harness with motor should it be a easy swap out?
planning on rebuilding the old one, but bulletproof the crap out of it when I have more time to spend on it.
Old Jan 20, 2014 | 04:50 PM
Unrealo4's Avatar
Unrealo4
You will want everything pcm and all harnesses. Big changes from 03 to 07.
Old Jan 20, 2014 | 04:56 PM
BLADE35's Avatar
BLADE35
You HAD an INJECTOR Fail and HYDRO Lock
the Tip Blew off the Injector
The Inject Tip Hit the Valve bent the Push rod or tip got Pined in maybe a way it didn't close
Its an Interferance Engine
Old Jan 20, 2014 | 05:04 PM
BLADE35's Avatar
BLADE35
You Might get away doing 1 head
Worse case a Piston But it maybe OK Needs Checked at TDC height
Old Jan 20, 2014 | 05:22 PM
dweillie's Avatar
dweillie
injectors are fine
hydraulic lifter issue flattened cam lobe, requiring tear down
nothing to do with injectors
Old Jan 20, 2014 | 05:28 PM
BLADE35's Avatar
BLADE35
So where did the White smoke come from Then
Said it smelled Like diesel fuel
Old Jan 20, 2014 | 05:30 PM
BLADE35's Avatar
BLADE35
Oil in Downpipe???
And Do you remember if this truck had a Sudden squeak upon shutdown Proir to the Catastropic Fail
Old Jan 20, 2014 | 05:33 PM
dweillie's Avatar
dweillie
the locked lifter bent pushrod causing rocker to break
believe me I WISH it was just a internal head issue, I was hoping that's what it was. ill probably just rebuild this one since its 07, go with upgrades and call it done. after all its only money right? lol
