Check Those Brake Lights
Old 06-16-2016, 08:30 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Took Blue out for a run today. She ran well in 90 plus degree heat. Got into a couple miles of stop and go traffic when this young couple in a Mustang convertible pulled along side, gave the thumbs up and said,
"Beautiful truck, but your brake lights are not working."
So I pulled off, checked wiring, verified flashers worked so cautiously continued on my way, using flashers when stopping.
Damn pressure activated brake switch is two and a half years old and was working a couple weeks ago when I brought the truck home after dark. Oh, well, I was going to remake the rear brake line anyway.
So, y'all check your brake lights often The quality of the currently produced switches is not that great.
NAPA has the Echlin brand so I think I will try one of them. Not quite ready to fab up a mechanically activated switch yet.
Old 06-16-2016, 08:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Wow! that's one of my biggest fears, not having brake lights.
Old 06-16-2016, 08:52 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,836 Likes on 1,835 Posts
Thanks for the reminder. I think my right rear isn't working. I keep forgetting about it until I'm on my way home after dark.
Also one of my indicators in my gauge cluster isn't working. I guess its time to bite the bullet and do some repairs.
I'll add them to my "to do" list for this weekend
Bobby
Old 06-16-2016, 08:53 PM
JPMallory's Avatar
JPMallory
JPMallory is offline
Sound advice for sure. I usually look for the glow against the back wall when I'm backing my truck into garage. I should probably start checking before I leave instead of when I get home..
Old 06-16-2016, 09:07 PM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Good tip Ray. I'm glad someone told you about yours B4 a mishap. It would be a good idea to check all lights B4 each cruise, especially when the truck is kept in a dark garage like mine . It's easy enough to check b4 opening the garage door and starting the motor. They lite up the door and front wall pretty good.
Old 06-16-2016, 09:40 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Quality may have little to do with the problemo. This switch is notorious for getting gummed up with dirty brake fluid. When this occurs, it no longer works.
C1AZ-13480-A (replaced 0A-13480) .. Brake Lamp Switch (Motorcraft SW-24).
Applications: Myriad 1940/66 Passenger Cars/Trucks, 1961/66 Econolines & 1966 Bronco's.
There are dozens of genuine Ford switches available NOS .. These were either made in the US or Canada.
Old 06-16-2016, 09:43 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,615 Likes on 1,456 Posts
I do the same exact thing!
Ray, I bought one of those low pressure switches from Mid Fifty a couple of years ago. It failed. I put original one in. I must have been 30 years old, until Mid Fifty sent me a new one. I noticed my left rear is not working right now. So I have to it. The one filament must be out as the taillight in that lamp still works.
Old 06-17-2016, 07:40 AM
johnnydevil55's Avatar
johnnydevil55
johnnydevil55 is offline
The past 3 vintage cars that I've owned I installed electric brake switches on the pedal. I had way too many of those mechanical switches fail on me. Just my 2 cents, but I've never had a problem with the electrical ones.
Old 06-17-2016, 05:45 PM
Flat Ernie's Avatar
Flat Ernie
Flat Ernie is offline
I use switches originally designed for Harley Davidson motorcycles. They generally activate at a slightly lower pressure and seem to last long enough for me so far (knocking on wood).
Old 06-17-2016, 06:05 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
I use a mechanical switch of the waterproof type used on heavy equipment . there only about 40 bucks
Old 06-18-2016, 05:17 AM
pweng1's Avatar
pweng1
pweng1 is offline
I use a mechanical switch on most all mine for that reason. One of my trucks in the past had both, which may sound like over kill but they use to hand out some big tickets for that.
Patriotic Rottweiler
07-02-2018 11:39 PM
mrad
07-30-2012 01:42 PM
Lukes66
02-09-2011 05:38 AM
im_pop69
Electrical Systems/Wiring
02-06-2006 03:38 PM
Quick Reply: Check Those Brake Lights
