Fuel Tank too far gone?
Old 02-02-2014, 08:21 AM
53FOPAR's Avatar
53FOPAR
53FOPAR is offline
53FOPAR has a good reputation on FTE.53FOPAR has a good reputation on FTE.
There are several kits available to clean and seal a tank. I used one from KBS (panel truck tanks are not cheap like pick-ups). The epoxy coating leaves a nice hard finish on the inside of the tank and stops rust.
Old 02-02-2014, 10:58 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
If I were going to replace my tank, I would buy a poly tank. The repro steel tanks I've seen don't usually say a thing about what material they are made of. Plain steel isn't going to cut it. Terne- (lead) coated metal is the standard for OEM's but I don't see any mention of this in the catalogs. Galvanized is so-so with gasohol.
Old 02-04-2014, 11:42 AM
lm987
lm987 is offline
lm987 is gaining momentum as a positive member of FTE.
New Gas Tank
Greetings,
I am in a similar situation with the gas tank in my 1950 F-1. Can anyone recommend where to purchase a new (behind the seat) tank that is made in the U.S. ??
Thanks
Old 02-04-2014, 01:23 PM
dmack91's Avatar
dmack91
dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
LMC has them for 200 and Classic Haulers for 275, but don't say if made in US.
Old 02-04-2014, 08:45 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
I would replace the tank for no other reason than for all the room it takes up in the cab. With the tank gone you can move the seat farther back...
ZSK
08-05-2015 04:19 PM
lee00
02-16-2015 06:56 AM
ZSK
10-12-2014 04:51 PM
ZSK
10-11-2014 09:24 AM
candoo
04-09-2014 12:40 PM
Quick Reply: Fuel Tank too far gone?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
