Service engine soon light on,low boost ??
Got in my 08' f350 75,9xx miles on it ,started it up and there it was the little engine icon lit up.started up fine,idles fine,got on the road then noticed it won't make more than 10# of boost no matter how much i push on the pedal.got in the truck again later on same thing but then i get the "drive to clean message" so i drove 25 miles or so and message still there.anybody have any ideas? Could they all be linked together somehow? Gonna get code tomorrow. Only have 1500 miles since last oil n fuel filter changes.drained the water seperator yesterday just like every month. Thanks
. Yes its the " drive until clean" message stays up the whole time if i push a button it tells me push reset to clear but comes back on and stays
drive to clean will stay on till it has finally come down some on soot levels. Sometimes if pulling a load it would take longer to go away since you are producing as much as you are burning.
Once enough has burned off it should turn to cleaning exhaust filter, that will stay on till complete in this case.
Much different then the normal routine regen.
It's goin in to dealer friday as its still under warranty. So will update the situation then.didnt have time to get codes checked today but on my to do list tomorrow.thats kind of what i was thinking some kind of sensor. Thanks for the input always appreciated
Just got code read came up p1335. Ecm has detected a minimum egr position above a calibrated level. Says probable cause short circuit condition or faulty egr valve. I wouldn't doubt a short circuit with my luck because truck went into shop a month ago about alternator problem and it turned out to be chaffed wiring right near plug on alternator.
yes...if you have an egr issue I can see where it is throwing a bunch of exhaust gases. So when you take it in be sure to tell them what you did in an attempt to ensure it was not your driving habits...save them from doing a manual regen till the other issues are looked at.
Wrench light and check engine light issue.
