Adjusting a hydraulic clutch??
So I just had my entire clutch replaced while another repair was taking place. What I've noticed is the "clutch engagement" has changed. Where as I would have the clutch start to engage/disengage at the 1/2 way point on the pedal travel is now the last 1/4 of the pedal. Is this a "normal reaction to a new clutch that just takes getting used to or is there an adjustment I can fine turn it with?
Do I just have to wait for it to "break in"?
When I replaced the clutch on my dearly departed 94 ranger, I replaced the bearings & disc only reusing the pressure plate and did not have this issue.
Thanks as always
Steve
Thanks as always
Steve
For me it was less hassle to take the master and line out than try to bleed it on the car. The lines just plastic so tie one the master and reservoir to one end of a 2x4 and the fitting to the other (vertically) Then tap on the line lightly to bring the air up... There's a good "how to" video on youtube...
cx300
06-15-2015 08:11 PM
Frozen_Joker
17
04-10-2014 08:06 AM
Henrys son
07-12-2008 04:58 AM
slow_v6_stang
08-09-2007 02:23 PM
