Summit Carb problem
Old Jan 13, 2014 | 10:37 PM
F-250 restorer's Avatar
F-250 restorer
Summit Carb problem
For three months I have slowly and gradually been tuning a new Summit 600 cfm vs carb. It is on a hp 300, so I knew it would need some tuning and dialing in. From the time of installation to now I've had problems starting the truck when it was hot. I thought that issue would vanish with the proper calibration. Neither float level, jets, idle air bleeds, nor any other adjustment has helped.
Now when I speak to Summit there is no warranty. Research turned up the same issue with the original carb, the 4100 autolite, which the Summit copied. I thought with the redesign they would have eliminated that problem. Whoops.
Has anyone else experienced this?
Old Jan 14, 2014 | 09:40 AM
F-250 restorer
Isn't anyone running a Summit Racing carburetor? Surely I can't be the only one experiencing this problem.
Old Jan 14, 2014 | 10:19 AM
turbohunter's Avatar
turbohunter
I would start with your own comment that it has trouble when hot.
Off the top of my head questions would be, is there a reason that it might be vapor locking? Is there a place where the fuel lines are in close proximity to a heat source? Is there insulation between the carb and intake manifold?
Why is the hot engine affecting it?
Old Jan 14, 2014 | 11:22 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Do you have a carb spacer? Or one of those 1/4 inch thick gaskets?
EDIT: What's the choke do when it's hot? If the choke closes too much that can cause issues.
Sam
lilsmokey
24
Oct 26, 2012 11:07 AM
The John
17
Mar 14, 2012 09:02 AM
oldfordman
Feb 18, 2005 04:17 AM
Slick66
19
Jan 7, 2005 09:24 PM
kai123
Mar 19, 2003 01:56 AM
