Vent visors on a 2104 Super Duty CC - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-13-2014, 06:43 PM
Go Big or Go Home!
Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
I bought some weathertech in channel visors. Rear went in fine the fronts seem extremely tight, and don't allow window to go up smooth and when it does it hits the top and the auto down kicks in..Has anyone got any tips on the install of these visors? Are in-channels the way to go or are the peel/sticks better?
Old 01-13-2014, 07:37 PM
thetiler's Avatar
thetiler
thetiler is offline
thetiler is gaining momentum as a positive member of FTE.
Mine were like that on my 2013
I would just touch the button till the window would seat in the channel
It took a little while but now that they worked themselves in I have no problems
Old 01-13-2014, 09:17 PM
TD&C Angus
TD&C Angus is offline
TD&C Angus is starting off with a positive reputation.
I pushed my fingers into the window channel to spread the weather stripping apart, then sprayed Windex into the channel to lubricate it. This solved the same problem that you are having. Good luck.
Old 01-13-2014, 10:34 PM
winginit's Avatar
winginit
winginit is offline
winginit is starting off with a positive reputation.
peel and stick are better. those will crack over time.
Old 01-13-2014, 11:38 PM
Stanggt24
Stanggt24 is offline
Stanggt24 is gaining momentum as a positive member of FTE.Stanggt24 is gaining momentum as a positive member of FTE.
I have a 2013 and bought the putco chrome in channel vent visors from Zeibart and had them install them. When I picked it up I was told not to open windows for 24 hr. For them to set up properly but this was done in August when it was still hot out. When I opened them after the 24 hr period they were set good except it took about a week for the passenger front side to stop making window stop going up at half way and go back down , but after that first week it has been fine with no problems. I would recommend the putco in channels !!!!!
Old 04-22-2014, 06:59 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
Really? Not after two years on my 150 that has been thru weather of +42c to as low as -51C. That is a 90degree temperature difference without a single issue. The stick seems old school.
yamaracer18
2017+ Super Duty
31
12-28-2017 08:30 PM
rhino_160
1999 to 2016 Super Duty
12-30-2015 10:17 PM
stangfan78
2015+ F150
09-05-2015 07:27 PM
Henry Ford the 8th
06-18-2015 02:18 PM
ufvj217
10-28-2012 12:28 AM
Quick Reply: Vent visors on a 2104 Super Duty CC
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
