How many horns?
Old Jan 13, 2014 | 06:37 AM
Rasputin53's Avatar
Rasputin53
How many horns?
The FSM says 2, there are the places for them on the radiator support, but mine only has one on the passenger side (LO) and there is no wire on the driver's side, nor does it look like a horn was ever installed there. Is there a harness that goes from the PS to the DS for the HI horn that I'm missing, or did it just never come with one?
Old Jan 13, 2014 | 06:58 AM
70-360fe's Avatar
70-360fe
Hope this helps, 68 is suppose to be the same as 69.
http://www.fordification.com/tech/wi...orncircuit.jpg
Old Jan 13, 2014 | 07:28 AM
Rasputin53's Avatar
Rasputin53
Thanks. So I am missing a horn and a pigtail. I see a trip to the yard in the near future.
Edit: Actually the DS horn is an R.P.O. so it had to be ordered so mine is as it came from the factory. But, I do like the two tone. Has more a-thor-ih-tie!
Old Jan 13, 2014 | 07:55 AM
orich's Avatar
orich
That beast needs some air horns on it for a little more road respect..
I've got a pair under the fender out of sight.. orich
Old Jan 13, 2014 | 10:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967/69 Custom Cabs, 1970/72 Sport Customs, 1967/72 Rangers came with two horns, 1967/69 standard cabs. 1970/72 Customs only came with one.
The high & low tone horns are the same as 1958/82 FoMoCo Passenger Cars except mid 1970's Lincoln's, T-Bird's and Continental Marks that came with 3 horns.
In 1983, Ford obsoleted the 1958/82 horns, replaced them with 1983 (and later) horns that have a different shape and bracket, so you might find these horns on earlier models.
Old Jan 13, 2014 | 11:27 AM
JEFFFAFA's Avatar
JEFFFAFA
Here's an idea. Mount the two horns you're going to use on tha right side. Save the left side area for a radiator overflow bottle.
Old Jan 13, 2014 | 12:26 PM
Rasputin53's Avatar
Rasputin53
There's definitely enough space to do it. The bracket is integral to the horn. The ones on my Mustangs have just a straight bracket as they just bolt flush to the radiator support. I never realized the bigger cars used a different bracket. I'll definitely be able too find those then.
And having a soccer mom soil herself because she cut me off is another interesting plan...
Old Jan 13, 2014 | 02:09 PM
arctic y block's Avatar
arctic y block
I had a set of Train Horns from JC Whitney once. Now them there would give
the strongest and meanest soccer moms wet bottoms now let me tell ya.
Damn things would dim the lights and almost kill the engine.
Old Jan 13, 2014 | 08:00 PM
351Cleveland C4's Avatar
351Cleveland C4
I've got one of them wolo bad boy horns. It has kind of a funny tone, but it's loud, and that's what matters.
Old Jan 14, 2014 | 09:15 AM
MIKES 68 F100's Avatar
MIKES 68 F100
+1 I have the 95db air horns in my passengers fender well too , I look for any reason to blast people ..lol
Old Jan 14, 2014 | 11:33 AM
orich's Avatar
orich
Oh yea, under mind is one 25" diesel Tk horn & one each of a 16" & 12" combo. running 150 psi to them
On the Tk horn, I remove the air bug opening deflector plate so it's now really load. I'm now really getting road respect from these *** holes at a stop light that are to busy texting when the light turns green
zoomeroo
Dec 26, 2013 07:32 PM
Auburn_in
Jan 16, 2013 11:57 AM
F250FarmBoy
Electrical Systems/Wiring
Dec 19, 2006 06:48 PM
StephenA
Nov 5, 2005 10:45 PM
79Lariat
20
May 28, 2003 11:16 PM
