1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
electrical question for a '65 F-100
Old 02-08-2014, 12:47 PM
peter sipp's Avatar
peter sipp
peter sipp is offline
I cannot find the Instrument cluster voltage regulator next to the speedometer or any where in that area. Out in the engine compartment close to the 3"X3" regular voltage reg. is a small similar looking little box to what is supposed to be in the cab, near the speedo. It is about 1&1/2" long X5/8" thick X 1" wide. There are 3 prongs coming out of it. there is one, mmm, 1/4" self tapping screw holding. Thank you fellow/gal slick 60's enthusists, cheers, Pete
Old 02-08-2014, 12:54 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
That sounds like the relay - for the horn, on the inner fender apron. The constant voltage regulator "should" be installed on the back of the speedo meter ? Dunno. Not sure for 65s though.
peter sipp
02-09-2014 11:07 AM
riggerparish
12-21-2013 02:14 PM
sparkyj
04-01-2012 12:22 PM
bronco2ok
Bronco II
02-20-2004 03:57 PM
Quick Reply: electrical question for a '65 F-100
