FICM dying again?
Old Jan 10, 2014 | 06:05 PM
mhauer's Avatar
mhauer
FICM dying again?
Hello
I hope someone has some insight as to what's going on with my truck. It has been bucking and stalling out recently and today it finally died. It is a 2003 6.0l F350 with head studs, egr delete, replaced HPOP,ICP,IPR and two months ago I had Ed rebuild the FICM and add the Atlas 40 tune to it. I am running the 100HP SCT tune in it. Im at 240k on the truck
I have the SGII in it. the ICP is over 500 but the weird thing is that the Volts are at 12.7 KOEO,11.9 crank and 13.7 run but the FICM main power intermittently goes 47.5-49v while running but then dies and wont start and then the FICM main goes to about 30v and slowly dies to zero.
The logic power is fine while running at 12v but now it jumps around 9v and also slowly dies to zero. Relay and fuses are new. I test the power at the underhood relay block and get 12.7 v but the SGII says different.
Could the FICM be dead already? Also, why the intermittent bucking and dying. Some days its fine all day and others are bad. May be a coincidence, but it acts up on rainy days and not really on the dry days.
Any one with any ideas? Thanks in advance
Old Jan 10, 2014 | 07:46 PM
USMCveteran's Avatar
USMCveteran
You need to post numbers koeo. Test your batteries and your alternator as that's usually what kills a ficm. Its hard to believe a ficm from ed is going bad.
Old Jan 10, 2014 | 07:57 PM
mustang_309's Avatar
mustang_309
it may be the FICM relay there was someone on here not to long ago had similar symptoms and it was a bad relay
Old Jan 10, 2014 | 08:00 PM
mhauer's Avatar
mhauer
Batteries test out good - only three months old Motorcraft brand- The alt is not that old but I will have it tested out tomorrow. I talked to Ed and he was very helpful. He thinks that it may be a harness problem abd I'm inclined to agree. I will check it out and let you know. Thanks so much for responding.
Old Jan 10, 2014 | 08:03 PM
mhauer's Avatar
mhauer
Relay and two fuses (50amp and 10amp ) are new.
Old Jan 10, 2014 | 08:07 PM
Misky6.0's Avatar
Misky6.0
Monitor your flp/flv input voltages. My ficm relay would not "latch" at keyon. My ficm input volts would drop without even bother to start. Flv would drop to 9, 6, 3,0. Fmp would be 4x flv, 36, 24, 12, etc. I replaced ricm relay fine since.
Also, i keep headlights and a/c off until glowplugs go off and voltage goes over 12.7-13.5.
Have your alt and batteries check. A bad battery can overtax the barely adequate alternator.
Bad bat/alt can kill the ficm, gotta ensure adequate battery voltage.
Sent from my Sprint PC36100 using IB AutoGroup
Old Jan 11, 2014 | 08:22 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
OMG! Two guys with relay problems that are my customers. Ack! The warranty liabilities!!
Seriously, though, I enjoyed our chat the other night (was it last night? Just entirely too much going on...).
I'd suggest replacing the relay yet again and of course swinging through your wiring harness pretty thoroughly. Wet weather should impact exactly nothing on the FICM.
Of course, the #1 way to kill any FICM, even if it IS one of mine is to starve it for supply side voltage. Going through these puppies like candy is I'm sure not the goal.
Let me know what you find!
Old Jan 13, 2014 | 04:00 PM
mhauer's Avatar
mhauer
OK It's fixed!!!! A big thanks to Ed at Ficmrepair.com. for suggesting what to look for. He is the man!
It was a chafed/broken wire in the harness. It was the red/yellow wire that turns on the relay that supplies the FICM. There were four other wires at the same location that needed repair. It was where the harness goes from the motor, under the steering column and as it goes back up towards the fenderwell, it was rubbing on the front edge of the shock absorber mount. I could have looked in next to the tire and seen it.
I could not have found it without Ed's help. I talked to him three times, asked him many questions and I was probably just a pain in the neck to him and he was patient and helpful. Aside from him being a good businessman, he's just a good guy period! I would say that if you need FICM help, call Ed or just burn the truck to the ground in your driveway. There are no other choices!
Old Jan 13, 2014 | 04:18 PM
npccpartsman's Avatar
npccpartsman
And why I don't recommend anyone else. Ed ROCKS. PERIOD.
Old Jan 13, 2014 | 04:19 PM
mustang_309
Thank you for the update, this is the type of invaluable that makes this forum such a useful tool. Glad you got her going.
Old Jan 13, 2014 | 05:30 PM
FICMrepair.com
Former Vendor
OMG guys...I am SO not worthy of this praise.
As I've said numerous times, I am just SO INCREDIBLY THANKFUL to be of service to you fine people. The brotherhood here is so incredible, so tight, so awesome. Words cannot fully describe it.
I'm very glad that you got your truck working again! That is just awesome!!
Old Jan 13, 2014 | 08:00 PM
dlibson's Avatar
dlibson
I disagree Ed, you also provide a great service for us. That's why I send all the FICM's we need serviced from the shop to you. It's a great deal I can offer with your help!
Old Jan 14, 2014 | 09:57 AM
mhoefer's Avatar
mhoefer
Yes, everyone can check their shock tower in drivers side, I have an extra shock strut bushing sitting on top of my shock to prevent rubbing the wire bundle right above it. I noticed it when I changed my own shocks a while back, and put it on then. It bet this problem area in the harness gets a lot of us eventually. Special thanks to Ed and the Op for posting their problem and resolution. It's a very good thing to watch out for and something preventative anyone can do.
topkuz
Feb 16, 2017 09:36 AM
DSMMH
May 19, 2016 10:23 PM
madmatt1186
Feb 2, 2015 11:00 PM
Hiflyer746
Mar 8, 2009 05:46 PM
Schuebo
Oct 17, 2007 06:30 AM
