Old Faithful build thread - 1979 F150 SuperCab 4X4
OK team time to update you on where I am at, today was a sweet day as I drop Old Faithful for a the first time in a while and started the run in on the fully Rebuilt 460 (Top and bottom). She is sweet and I cannot say more!!
Here is some pictures of the some of the work, I also started a blog (Old Faithful | 1979 SuperCab 4X4 Longbed – Project) to track the journey of her rebuild.....she is never for sale and part of the family!
<iframe src="https://www.flickr.com/photos/86863150@N06/11868459385/player/e1def682ce" height="540" width="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
<iframe src="https://www.flickr.com/photos/86863150@N06/11868466645/player/af2511f5c8" height="535" width="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
<iframe src="https://www.flickr.com/photos/86863150@N06/11868743305/player/11e78a5cfc" height="480" width="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
<iframe src="https://www.flickr.com/photos/86863150@N06/11869170514/player/b74dfd5390" height="462" width="640" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
Since i brought her back from Montana USA to home here in Australia the below has been completed.
Cheers for now, more work to plan!
- New Chassis Bushing all round
- New Suspension bushing all round and tie rods
- New Shock and spring bushing
- Diff leaks fixed and fill Diff (Dana 45/60 work)
- Transfer case checked, oil leak fixed and painted
- Brand new custom build C6 Auto Geabox – had a T18 Manual in her before
- New thermal fan and custom kick down lines
- New Steering column, steering shaft, auto gear stick and steering wheel
- Radiator remove, flushed, service and painted – new hoses fitted
- Removed old bulb fuse box and upgrade to Blade fuses with a extra panel for expansion
- Ford 460 Big block removed, full top and bottom rebuild – minor stroke and oversized pistons etc
- New Edelbrock polished Water pump
- New Clapper starter and wiring, new solenoids and battery
- New lights fitted with upgraded wiring harness
- Rim remove and laser cut .02 of mm to remove oxidisation
- Midship fuel tank remove and restored
- Lot more little items, to many to list
crazy96863
62
05-30-2017 12:22 AM
shrekau
02-11-2013 08:55 AM
Shrek_Australia
11-23-2012 09:46 PM
glovemeister
66
12-21-2010 11:53 AM
