grown man about to cry
Im new on here and have read a lot done a lot but no success. I have a 99 f250 super with a 5.4. Manual lock outs in front. Its a plow truck/work truck/only truck. Everytime I hit a bump it grinds bad until I hit another bump.Had a mech. install new transfer case and t motor because of not swiching, now that's not an issue. still got a grind, replaced a lockout and everything was good. ran it then got a noise so I had to cut the other one off (seized) replaced it and still getting the noise. im lost
Welcome to FTE, F'aford.
Sounds like a good, basic, honest truck.
What exactly do you think is grinding? I get the clue from your below responses you seem to think it is something in the drive train.
He replaced your transfer case? Seriously?
Is this grinding noise related to speed, engine RPM or does it vary with the transmission?
Sounds like needle bearings to me as well. The bearings are replacable. Check out this guys tech articles. Also 1975stroppebaja on here has some good ones as well.
Welcome to guzzle's Modifications Web Page
