51 F5 Rear Brake Question
OK, I am about 1/4 of the way through the rear brake job on the old F5, I guess I didn't take enough pictures and the manual is not clear on the question I have. Since I had to take the drums to a machine shop to get turned, I removed everything at once, and now I don't have the "other side" to look at.
This style of brake (Double Anchor) has one brake shoe lining that is long (primary), and one that is short (secondary) at each wheel. Which one goes where??? The manual shows the primary brake shoe on the left and the secondary on the right. Does this hold true at all 4 wheels??
I will post some pictures to my build thread tomorrow. Like most of you, I am sick of all the rust, crud, and grime, so everything is getting cleaned and painted as I go. On top of that, I have two weeks off, so now it's time to play catch up on all the work I haven't done on the truck in the last couple of months. AND, Santa might bring me a hoist for Christmas .
Thanks for the help,
Eric
Eric
On the double anchor "Lockheed style" brakes, the big shoe goes to the front see here: https://www.ford-trucks.com/forums/1...l#post13595782
Eric
Eric
I just happen to know an "old school" machinist that did them no problem, and it only set me back $150. His owns North Central NV Machine. It is a machine shop in Carlin, NV, and he does a lot of custom work for the mining industry.
Question for Chuck
Any idea what the tolerance for the front drums are? I just got mine off and they are hammered . Nice rivet grooves in each drum, these might be toast???
Chuck
Chuck,
Just out of curiosity how much was the asking for someone to reproduce the drums? I know the tolerance is .020 for fronts and .060 for rears but would it be possible to take more off and use thicker shoe material? I did see a place online called Dynabrake who says they have the ability to build drums to spec. I'm sure it would be pretty pricey but didn't know if anyone had checked them out.
Chuck,
Thicker linings would work, within reason, of course. The issue is that the diameter of the drums has to match the diameter of the shoes, since they are rigidly mounted. Odds are the shoes would have to be ground to fit the drums.
Chuck
luke-gr
10-26-2010 10:39 PM
