blactic plastic piece on center upper section of 7.3
Does anyone know a aftermarket piece to replace the stock one that breaks on so many?? I cant even find a stock replacement for the one that broke on my engine. Would be nice if there was a nicer aftermarket one to replace the cheap plastic one that came stock on these trucks. Even a metal one that would be more dressy than the stock
Just took a stab at it, I have not had anything break on mine so I am just making a guess. Hopefully the OP will chime in and give us more detail about the specific piece.
They may be referring to the fuel bowl cover that has "power stroke" on it
I have seen it listed as an engine cover although it does not "cover" the engine. I have also seen hpop cover and fuel bowl cover used to describe the same thing; however, if you want to use engine dress cover then I suppose that works also....
the engine dress up cover is the first thing i take off and throw in the garbage on anything i get.
the only purpose it serves is another thing to take off and put back on when doing maintenance or repairs.
If you want a stock one, call the local Ford dealer and order one, they are around 30 bucks or so if I recall correctly. If you want something a little more fancy, refer to the link I provided above or do a similar internet search and find other options.
Here is the number to your local Ford parts department 888-287-2615
Ive seen some on the obs trucks that cover a much larger area... and have a hinged door you can just lift up to change fuel filters. It may need an obs bracket to retro fit.
I have now and that is the item I am speaking of so thank you all very much that is just not my forte I have seen others that looks really nice I just can not find a place to purchase such items
