Stock bolt pattern?
Old Jan 5, 2014 | 09:17 PM
Brody Olson's Avatar
Brody Olson
Stock bolt pattern?
Wondering the stock bolt pattern is for my 73 F-250. I know in millimeters it's 8-165.1 but i'm wondering what that is in inches. Wondering if the stock rims from an 05 duramax will fit, I know those are 8-6.5 and I know some dodge rims will fit. Let me know.
Old Jan 5, 2014 | 09:43 PM
Fordworth's Avatar
Fordworth
It is 8 on 6.5". The Chevy wheels should bolt up fine. I'm not sure how the backspacing compares to the wheels you have now but I doubt it's much different.
HIO Silver's Avatar
HIO Silver
Luk it up fer yer edukashun.
Bolt Circle/Pattern Guide & Cross-Reference Database
Beware! Though bolt patterns can be the same, they still might not fit. Sometimes the hub center bore is too small to fit over the snout...
... caveat emptor.
Old Jan 5, 2014 | 09:49 PM
Fordworth's Avatar
Fordworth
... caveat emptor.
Oh yeah, I forgot about that part. I'm pretty sure it's not an issue with the pickup wheels but hummer H2 wheels are often problematic.
Old Jan 5, 2014 | 09:55 PM
tbear853's Avatar
tbear853
Wondering the stock bolt pattern is for my 73 F-250. I know in millimeters it's 8-165.1 .
25.4 mm = 1 inch, thus 165.1 mm / 25.4 = 6.5 inches.
Old Jan 5, 2014 | 10:05 PM
Brody Olson
ok sounds good. Off subject but do you guys know how much one of these trucks weigh stock? its a 4x4 with a 360 and a 4 speed. Swapping the original intake with an aluminum one and stock manifolds with headers.
Old Jan 5, 2014 | 10:22 PM
Fordworth's Avatar
Fordworth
It should weigh in around 5500 +-
Old Jan 5, 2014 | 10:52 PM
HIO Silver's Avatar
HIO Silver
For reference, an Edelbrock Performer is 22 lbs... an OEM intake? Ha! You'll almost blow a brain gasket removing it! Just get it close to the fender and then heave it over the side...
Old Jan 5, 2014 | 11:01 PM
Brody Olson
haha I knew they were pretty heavy. I was planning on using an engine hoist to remove it.
Kelly Aitken
29
Jan 24, 2017 08:35 PM
Kalve
20
Mar 22, 2012 04:47 AM
jleal_21
Nov 24, 2009 02:41 AM
GeneralC.
Apr 18, 2008 09:14 PM
Bobs60F100
Mar 4, 2001 09:10 AM
