New Member 47 1/2; ton
Hello to all. hopefully ever one had a great xmas and the New Year is starting out great.
OK was wondering what i would need to do to add shocks to the front and rear as i see no mounts also need some info on the merc 8cm motor trying to figure out what year it is thanks for any info and i will be asking you all many more questions thanks this looks to be a great forum
Welcome to the site. I'm sure you'll find tons of info here. On the frame you'll find the holes for the shocks. 1/2 tons had front and rear shocks standard. They are called Houdaille, but many call them lever shocks. Tube shocks were optional for the fronts, using the same bracket as a car, adapter kits were also available from the aftermarket. You can find them on eBay quite often. Tube shocks make a great improvement over the Houdailles. I switched my 46 to tube shocks in 1996 and am glad I did.
WNDOPDLR
09-05-2013 04:57 PM
retro48/52
02-04-2008 07:40 PM
460
27
07-19-2006 06:47 PM
