Original steering wheel on new aftermarket column?
Hey guys, I was thinking of ordering an aftermarket steering column from summit racing and am wanting to keep my original steering wheel. I have been searching and I can't find an adaptor or anyone who's done it. Does anyone have any info on something like that? Thanks
If your looking at buying and Ididit or Flaming River tilt column they won't accept our trucks original steering wheels. These columns use a splined shaft that accepts 69 and newer GM style wheels. Do a search there are several vendors making reproduction wheels for use on the tilt columns.
Cut the center out of a GM steering wheel and weld it in place of the existing center, made my smaller diameter caddy steering wheel that fits a GM column that way. A little work and it will be good to go. I used the smaller wheel ring as well but you wouldnt have to.
original huge wheel
gm wheel from a 70s monte carlo
center cut from monte wheel
smaller wheel in progress
duraglass filler
sanded and painted, not show quality but works just fine.
original huge wheel
duraglass filler
I don't know about yours but the wheel on my 52 wraps around the outside of the column. All the new columns I've seen the wheel hub sits behind or inside the column. Since I like the look of the original style I am going to modify it as necessary to suit my needs.
No epoxy, all metal welded together and then used duraglass to form the missing pieces. It was what I had on the shelf so I figured if it didnt work I could grind it back out, but it actually worked well. The more time you take shaping it and sanding it the better it will come out. I do not know of the epoxy products would work better or not, I have not tried them.
Pappaws53Pickup
05-07-2011 03:13 PM
joedellcarter
02-19-2008 02:57 PM
