IMPORTANT Michigan BS - Required Reading!
I love when people think they are mechanics! "Yeah, so this is what it's doing and this is what it is. Pretty sure" *Has absolutely nothing to do with the issue at all*
Andrew $8.99 plus free shipping sounds like a steal or maybe it was supposed to be $89.99 and someone messed up. If not.. then you're probably going to get like a fluorescent light bulb in a box haha
Now that would be pretty funny!
since we didn't end up taking my truck out west i never did get the LED bar from rich installed on mine. i need to fab some brackets, and i'm going to modify the reflector a little bit as well first.
i'm the only one in my househould who has the day off tomorrow, so i think it's going to be a (long overdue) spa day for the truck. this misfire is still getting worse, so time to see if i can really figure it out.
You as well John, along with everybody else!
merry belated, gentlemen.
i did right away when i got it from you, but didn't get much results since i forgot you need to plug the Ford dongle in. didn't remember that part until recently.
the plugs were replaced when i bought it, and i've played the swap COP game and chase the code. misfire is on cylinder 8. my guess is either a faulty spark plug or something with the fuel injector.
i never did get to the truck this weekend. Christmas stuff took precedence.
Which plugs do you have? If its that crappy 2 piece it wouldn't be the first time i was told the plugs were changed, but what they meant was a plug was changed.
they are the ones that used to be a two-piece design, but as far as brand i wish i knew; when i made the deal on this truck i just told them i wanted them all changed, but unfortunately i hadn't done quite enough research to know to tell them to use Motorcraft.
It's just the last 2 5.4 3 valve engines I've had to work on have both been told the plugs were done, but by the time i get to the point of eliminating everything else, i found that only the plugs causing problems were replaced.
