TTB bracket bolts came loose
Sunday on the way home I heard some unusual knocking noises coming from the front end. When I got home I grabbed a flash light and looked under the front end at the front suspension and could see the TTB bracket that bolts to the cross member was loose.
My truck is a 92 F250 4X4 5.8L
Is this a common occurrence or just a one time thing?
I got under there and cleaned everything up and used some RED Loctite thread locker and tightened everything down. Hopefully I will not have to mess with that again.
Matt
Matt
Well then they were stretched/worn out because they went on really easy like a regular flanged nut. I am sure being a crush style lock nut Ford would want $10 each for them. i will monitor them regularly to make sure they stay tight. if they loosen up again I will buy new crush nuts and use more lock tite.
Matt
Matt
Received 3,102 Likes
on
Wyokaboy
12-15-2007 10:59 PM
Franken-Truck
09-07-2005 09:11 PM
