Slip Joint Regrease Urgent Question
Old Dec 30, 2013 | 03:09 PM
jwhopson's Avatar
jwhopson
I decided to undertake this little no cost project and ended up with a question before reassembling. I did mark both ends but how "crucial" is it that they align back up 100%, can they be off a spline? I noticed the rear one was about three splines off. Does the double spline in the front make a difference where it aligns?
I also noticed some leakage - it is in the rear diff, where the u-joints connect, does it look like an oil leak to you?
Old Dec 30, 2013 | 03:19 PM
excavator's Avatar
excavator
100% lined up or no good. The yoke at each end have to be inline or no good
Old Dec 30, 2013 | 03:20 PM
jwhopson's Avatar
jwhopson
OK, thank you, back to the drawing board . Appreciate the quick reply.
Old Dec 30, 2013 | 04:09 PM
jwhopson's Avatar
jwhopson
Well, I was so careful to make sure the line was drawn correctly, etc.. and I think I have it lined up, however, what would I notice if I was off? It seems weird that with the u-joint the way it is how could it get mis-aligned since the ujoints only fit one way (having it jacked up without moving wheels).
Anyway, what would I notice if I was not 100% aligned?
Old Dec 30, 2013 | 04:14 PM
excavator's Avatar
excavator
a good viberation.
You want to look at the end caps at each end. They must be perfect. Not even 1 tooth off
Old Dec 30, 2013 | 10:30 PM
jwhopson's Avatar
jwhopson
Hmm, well, I think I just got lucky then because I put it all back together and went for a drive, up to 60mph and no vibration yahoo!
Thank you!
I think what I did wrong was marked them both at the same time so when i went to unbolt it, it slipped and blah blah blah.
Old Dec 31, 2013 | 07:20 AM
Dan V's Avatar
Dan V
Thank you!
I believe the spline has a couple of "teeth" machined in a skip pattern, only goes together one way.
Old Dec 31, 2013 | 08:45 AM
Bigtruc's Avatar
Bigtruc
I don't really believe it is that important to line it up perfectly. I replaced mine with a new one which means I had no way to line anything up & I have absolutely no vibrations. Biggest thing I think is just to have a good, well ballanced driveshaft. Also the leakage is most likely your rear pinion seal. If you had the pinion off anyway its the perfect time to replace it. Its a $12 dollar part & a 5 min job.
Old Dec 31, 2013 | 08:57 AM
timmyboy76's Avatar
timmyboy76
replacing that leaky seal, may be a 5min job, but setting the "crush-sleeve" is an all new ballgame. Its not a, remove yoke, pop seal off, install new seal, then hammer yoke on with impact...job
Old Dec 31, 2013 | 10:36 AM
Bigtruc's Avatar
Bigtruc
No that is true. Propper torque of the pinion nut is crucial. I believe 150 ft/lbs is the factory spec but don't quote me on that.
Old Dec 31, 2013 | 10:52 AM
strokin'_tatsch's Avatar
strokin'_tatsch
If you call pulling the diff cover, diff and ring gear, pinion, remove/install pinion seal, check bearings, install new crush sleeve, install pinion with proper pinion bearing pre-load, install diff/ring gear, diff cover, new fluid a 5 minute job, you're more of a wrench than I am. LOL It's not a hard job, but it's definitely not a 5 minute job to do it correctly... Especially if any of those bearings need to be replaced for any reason.
Old Jan 1, 2014 | 03:18 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
That leak in the picture is not the pinion seal, that is gear oil wicking down the pinion shaft. You would have to pull the yoke, clean, apply sealer and re-torque the pinion nut. If you do that you might as well replace the pinion seal but don't forget to grease the inside of the seal before installing the yoke and no you don't need to replace the crush sleeve.
Old Jan 1, 2014 | 11:30 AM
guitarpicr's Avatar
guitarpicr
Had the same problem when I did mine a few years ago but mine was on the ground & even though I thought I had the wheels chocked it moved ever so slightly (Guessing here) & when I went to put it back together it took me a while to get it all lined back up.Amazing how a little grease quiets down the clunks. Now if I could only do this to my knees & back !
1981 F100
Nov 22, 2018 08:10 PM
Vijay
15
May 28, 2014 04:49 PM
Rayzors250
1978 - 1996 Big Bronco
Jan 25, 2012 02:15 PM
sparky
Jan 11, 2009 07:43 AM
briancowen
Jun 9, 2003 11:07 PM
