1993 Yellow Gen 1 Lightning F150 Street/StripTruck
Year: 1993
Make: Ford
Model: F-150
Price: $7000
Mileage: 150000
Color: Yellow
Private or Dealer Listing: Private Listing
Location (State): LA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Yellow
Engine: 351
This truck is street legal. Has all workings lights, blinkers, windshield wipers, etc. Can be licensed for street use. Current tires are legal for street use.
Asking $7000 Firm. Possibly trade for 4x4 F250/F350 5.4/6.8L. Serious inquiries only.
ENGINE:
*Stock garaged freshened roller short block
*Canton 7 quart deep oil pan
* TFS-1 Cam w/ 1.72 rockers
*Ported Edelbrock Performer RPM heads
*Ported stock lower GT-40 intake
*Cut, ported, and shortened explorer upper intake manifold
*80mm TB
*42 lb injectors
*80mm Pro-m Mass Air Meter
*Main harness converted to mass air by Ed (Struckby) using an A9L Mustang
PCM
*Anderson Ford Motorsport Power Pipe Intake
*Mac Products 1-3/4" long tubes to custom 3" exhaust with x-pipe, bullet
mufflers, and turn downs
FUEL SYSTEM:
*10 Gal aluminum fuel cell
*Walbro 255 pump w/ Russell nylon braided line connected to factory fuel
lines
*Stock 1995 fuel rail and pressure regulator
CHASSIS:
Front:
*DJM 3" front lowering i-beams
*Custom 2" lowering drag coil springs
*Calvert Racing 90/10 shock
*Manual steering box
*1995 spindle w/ bolt on calipers, slotted & drilled rotors
*15x3 Bogart Force-10 rim w/ 28x7.50 MT ET Front
Rear:
*DJM 2" hanger & 2" shackle
*Custom modified factory leaf springs w/ Calvert Racing spring clamps
*Calvert Racing 9 way adjustable shocks
*Caltrac bars with newer updated longer bars
*15x10 Bogart Force-10 rim w/ 295/65R15 MT ET Street Radial
*Stock 4.10 gears w/ Detroit Loker & Ford Racing girdle cover
TRANSMISSION
*Homebuilt C4 transmission from a 1972 Torino
*Transking reverse manual valve body
*Transking 9" 3000 stall converter
*Ford Racing deep pan
*Superduty size cooler w/ stainless braided teflon transmission lines
Lots of other misc mods and parts to go with. Too much to list. Pics are old. Clear coat on paint is peeling badly and the truck will need to be tuned. Ran a best of 12.30 with a 1.60 60ft. Would easily be a high 11 sec truck when tuned right.
RC Dan
02-18-2008 06:24 PM
f250rollinon37s
17
03-02-2007 09:02 AM
