stub shaft mangled and took out other parts
So this happened to my shaft.
Basically my stock hub was destroyed and half missing also. Now I'm trying to get it back together and I know I'm missing stuff.
My drivers side has a snap ring and a nut, trying to find those correct parts online pretty much.
Trying to convert to warns also, so if anything else is needed I need to know
is this stuff all im missing?
Super Duty Thust Washer Kit
Axle Shaft Snap Ring, D60
on
You'll need these, too, besides the obvious. Super Duty Outer Axle Thrust Washer Superduty D50 & D60 Hub Vacuum Seal Goes between stub shaft yoke and back of hub assembly.
on
I would install the vacuum seal to keep water and dust from entering the hub from behind. While the thrust washer does ride against the back of the hub, it needs lubrication and the seal protects it. The grooves in the thrust washer would allow contaminants to leak through and damage the needle bearing.
'99F250
08-04-2019 08:11 AM
grif95
05-06-2017 06:59 AM
keyul
36
01-29-2012 11:14 PM
afonda
04-27-2009 08:28 AM
