1966 f100 straight 6 240 rough idling
Could be several things. I'd start with the PCV valve. Look for a hose going into the valve cover. It's attached to the valve. You should be able to pull the whole valve, hose and all out. Shake the valve. If you can't hear it rattle, it's bad. I'm pretty sure a new PCV valve is less than ten bucks. Standard practice to replace it during a tune-up.
LARIAT 85
09-28-2007 05:34 PM
dgpruitt
03-25-2005 05:14 AM
