Degas bottle empty, very scared...
OK, I just picked up my new reman water pump and have a few questions....
Can I use silicone seal on the wp gasket? can I use it on the metal hose piece (the one under the thermostat - it's larger and it has an o-ring but I am reusing the housing and thought I could use silicone to help seal.
Do you know what the torque specs are for the water pump housing bolts? Do I use antisieze on them? They were not that tight so I think I could easily over tighten them.
Thanks guys and wish me luck tonight on this project......
TAILGATE.... Thx for your comments about the filter, I was always sort of "eh" about them but have had it installed a few months and noticed the slow trickle through it so now I am excited to cut it open, will insert a new one now - super thanks.
With the 2 waterpumps I replaced, I ended up replacing the thermostat housings within a week afterwards. Next time I'm going to change the housing with the water pump. BTW, the new thermostats have a rubber o-ring that covers the edge of the thermostat. Much better the original design. Also, don't go crazy torquing the t-stat housing bolts.
Need HELP Fellas. The lower inlet tube that mates up to the wp just below the thermostat (I think it might be called wp connector or something like that)- is leaking. I did put the oring back on, but it was pretty weak oring. I know you said no silicone but I along with Napa, Autozone, Ford seems to have an issue of trying to find this tube to buy - apparently it doesn't come with the remand wp but does come with the new wp's. So, my dilemma is, if I disassemble the two bolts holding it on and the oring is OK, can I use silicone in that spot?
Because I am at a loss of what to do - this was an area where I felt the bolts bottomed out and the surfaces were mated but it just didn't feel like they sealed - apparently not .
Any help is appreciated on the Merry Christmas Eve.... ::
My better half always laughs at how I don't take action until checking with FTE members first, but I rarely ask her for permission .
OK - thanks, I guess I was just overly concerned about silicone usage. I suspect there are some other areas that will leak but have not been able to really charge up the system until this gets resolved. A few xmas errands first (or I won't have a better half) and then back to the truck.
thank you fellas for the quick response, will start back at it around 1pm.
on
Anyway, if you are buying silicone for sealant, some of the best stuff I've ever used is the gasket maker stuff. ON EDIT: It's the Permatex "The Right Stuff Gasket Maker." It's about $15 for a can, but you can use it for your rear differential and just about anything else. The longer you let it cure before installing on something, the more gasket-like it becomes. And the can will last forever. I will say it's probably overkill for what you're using it for though...but...
I just wanted to close the loop without jinxing it. IT WORKS, no leaks , thank you everyone. I have let it idle, ran it sort a hard and watched the coolant level and so far everything looks great. Thank you!!!
Tailgate - I replaced my coolant filter and WOW it just squirts into the degas bottle, I had forgot what a non-clogged filter works . I am excited to cut my old one apart to see how bad it is.
#29
Others here are equally interested in your results.
I have never even heard of a coolant filter that's completely clogged, so I am standing by for your results!
I'm suspecting it will be "ugly", but revealing!
Oh yeah, one more thing.........
Pop
Pop
#30
