Tire shop damaged my ignition switch!
I have been a repeat customer of this place and even referred people here. I went in on Monday for two new tires in preparation of a road trip and explicitly told the service adviser to replace the right front and the worse of the rear and put them both in front.
After waiting for over 3 hours they finally tell me my vehicle is done and that I can take one of the tires I replaced with me as it still has a good amount tread on it. He says they were busy and didn't have time to rotate the better tire onto the rear. So he says to come back another day and they'll do it.
So I come back Friday (today) and explain I need this good tread tire put on the rear and the service adviser at first wanted to charge me but then agreed to do it free of charge as it was their mistake. Then the "technician" who was pulling my van into the shop damaged the ignition key system so badly the whole key assembly just freely rotates and the vehicle can't be turned off!
I ask them what they did and they said "nothing we just turned the key." So I left upset and went straight to my mechanic. Turns out they applied so much force to the key assembly that they broke a part in the steering column that actuates the starter mechanism! I am now waiting for my mechanic to find the part and the whole steering column is disassembled. Be careful where you take your vehicle. I lost my desire to take the road trip and everything because of this.
What year is your van? That plastic plunger thingy broke right?
The connecting rod that shifts the box that controls AUX/OFF/POWER/START functions broke. So when I turned the key it would just free wheel and not do anything. SO rather than order the specific part from the dealer the mechanic wants to just replace the whole steering column with my ignition.
I just bought a 1984 E-350 460 ci coachman motorhome, doesn't start when i use the ignition switch, but can jump the starter relay to get the engine to turn over. Ignition switch seems to be gummed up, in other words, it doesn't snap back from the start position to the run position. Also no power to electric fuel pumps. Does anyone have any info. RV has been sitting a ggod amount of time, would just a key cylinder take care of this problem.
Thanks
Thanks
you most likely have the same problem. The springy return is in the actual electronic ignition switch. It is connected to your ignition cylinder via actuator and rod. The actuator is a piece of pot metal and under alot of torque and pressure. I am surprised these lasted as long as they did.
SOME of the parts in the steering column are under spring pressure and require tools not in the average tool box.
gts2
05-17-2017 10:37 AM
irfreddy
37
07-20-2016 12:53 PM
Kommandant
01-15-2012 08:51 AM
Smurf-Slayer
1983 - 2012 Ranger & B-Series
06-12-2006 08:46 AM
