wont start when hot
Old Jun 24, 2003 | 07:35 PM
shane43028's Avatar
shane43028
wont start when hot
I have a 78 F150 4x4 with a 351M runs fine now (finally,after a lot of work)but the engine has less than 5000 miles on a reman.
My problem is after running awhile (a few miles) I shut it off and it wont restart till I let it cool down.
What Gives???????????
Old Jun 24, 2003 | 08:03 PM
sparky's Avatar
sparky
wont start when hot
When you say wont start do you mean it wont turn with the starter or it turns but wont fire?
If it wont turn...could be starter or wires or even timing to far advanced.
If it turns over but wont start...do you have spark? if not could be the coil or the ignition module.
Or do you have spark but no fuel ?? if no fuel could be fuel line getting too hot and "vapor locking".
Or maybe the fuel is boiling out of the carb and flooding the engine...try holding the pedal to the floor and see if it starts.
Hope this gives a few ideas, if you tell us more of the symptoms we can be of more help
Old Jun 24, 2003 | 08:05 PM
tellico racing's Avatar
tellico racing
wont start when hot
Does it turn over? just click?
Old Jun 24, 2003 | 08:16 PM
shane43028's Avatar
shane43028
wont start when hot
The starter will turn it but almost sounds as if battery is dead.But I have new battery,plugs,wires,solenoid,fuel pump,fuel lines,starter.
Cools off after a few minutes and runs fine again
Old Jun 24, 2003 | 08:28 PM
Mil1ion's Avatar
Mil1ion
wont start when hot
Hmmmm.....No Hot start.
I would suggest the starter is on its last legs.
This problem is most noticeable on a truck with headers.
Old Jun 24, 2003 | 09:20 PM
bigf150's Avatar
bigf150
wont start when hot
the timing may be too advanced
Old Jun 24, 2003 | 09:59 PM
fozzy's Avatar
fozzy
wont start when hot
I agree. The timing sounds to advanced. maybe have the vaccum advance line on wrong port of your carb?? thats a common mistake.
Old Jun 24, 2003 | 11:42 PM
sparky's Avatar
sparky
wont start when hot
I still vote for timing but...check and make sure the battery + wire to the solenoid, the starter wire from the solenoid to the starter and the battery - wire have clean tight connections and the wires arent frayed/ corroded.
Also make sure the wires are large enough...I like to run doubled 6awg for all of them. Gives the starter as much oommpphh as it needs
Old Jun 25, 2003 | 05:20 AM
shane43028's Avatar
shane43028
wont start when hot
Thanks once again for the help guys
Old Jun 25, 2003 | 09:09 AM
F350SuperCab4x4's Avatar
F350SuperCab4x4
wont start when hot
i had the same problem on my 400. i put in a high torque mini starter from summit racing ($160) and wraped some insulation around it and it works great now.
Old Jun 25, 2003 | 11:21 AM
KJKozak2's Avatar
KJKozak2
wont start when hot
I'd bet dollars to pesos the starter is getting too much heat from the exhaust.
As I stated in another post, I had the exact same problem and installed a piece of aluminum between the starter and y-pipe. It made a definate difference, but I could still use more insulation.
Maybe try some of that header wrap around the exhaust near the starter.
Just a thought.
Kevin K.
