Looking to buy an '03 6.0L Excursion. Anything I should be aware of?
So my husband and I are looking to buy an '03 Eddie Bauer 6.0L with 170K miles. Are there any significant issues we should look for in this truck or things to be aware of?
We are new to diesels so any help in figuring out the gotcha's would be appreciated.
I just went through the process myself. 03 Eddie Bauer 6.0 4X4 with 105k. Read as much as you can from this thread, then read it again:
https://www.ford-trucks.com/forums/9...used-6-0l.html
I'm very happy so far with my purchase. I have enough set aside to take care of any issues that may or may not arise in the future. Good luck and I hope you are as happy with your decision as I have been with mine, so far.
I would plan on replacing ball joints, mine were loose on the passenger side when purchased, driver's side was tight. I replaced the passenger side and now the driver's side is noisy.
Are you looking to lift the truck or stay stock?
I don't think there is any difference between 03 to 05 Excursion excepted there was changes in engine production between 03 to 04 then other minor changes from 05-07. Each engine has their good and bad. It is all 6.0L PowerStroke Diesel...
make sure to check the adjustable pedal function, test many time to make sure the cable isn't broke. That cable will cost you more than $600 just for part alone.
