1996 ford f150 5.0 engine will not start
The ICM is the only link to the Ignition Coil. The ICM grounds the Ignition Coil and if the resistance in the Ignition Coil is low it would cause higher current to go through the ICM over heating it.
The PIP in the distributor would have no effect on the ICM heating up. The PCM Computer tells the ICM how long to ground the Ignition Coil. The longer the ICM grounds the Ignition Coil the hotter it will get.
As far as I can see the Ignition Coil and the PCM Computer are the only two items that could heat up the ICM. Only other factor would be low voltage on the wire from the Ignition Switch.
1996 5.8L won't fire
I am having a similar problem with my 96 5.8L, sometimes it starts on a couple of cranks, sometimes not at all. I had it running on day and it just stopped and would not start again for a week and I tried every day, when it did start it fired right up after a couple cranks. I am not driving it very much as it is not very reliable and want to sell it, but I want it to run proper for a better sell. I replaced the rotor and cap, ignition switch, and still no luck, help is needed.
Hey Guys,
So it was the pip sensor in the distributor... Or at least something in the distributor. After were replaced the distributor with a new one and got the spark plug wires where they are supposed to go, we had zero running problems. No over heating ignition control modules, plenty of power and better economy. About 2.5 mpg better. Got over 17 mpg on the highway. We made it home fine. About 2000 miles of continuous driving. Was a wonderful feeling! Thanks for all the help everyone! It was much appreciated!
Bondora68
01-04-2019 12:25 PM
Ryan313
20
03-28-2018 08:24 AM
Bear999
13
10-03-2015 09:23 AM
lbagatewood
20
01-15-2007 01:52 PM
My Clunker
08-03-2003 11:08 PM
