6.7 Intermittent Will not Crank
Hi All- Long time reader. This is a great site. I have a 2011 F250 w/6.7 Powerstroke. Love it. In September I came out of work, turn the key to on position...no glow plug indicator light, no high pitch whine of the fuel pump and most importantly, it won't crank. Gauges all light up, but no glow indicator, no fuel pump sound and no crank. Get towed to dealer. Next morning they try it, and it starts right up. They can't get it to fail. Sent me home with no trouble found. A few weeks later, same condition in my garage. I had thought that maybe there was some sort of safety switch that perhaps thought it wasn't in park. I put in neutral, roll back about 6 inches, glow plugs light, fires right up. Now I think I'm on to something. In the last 2 weeks, it happened 2 more times, and both times I'm able to get it to light up by rolling a couple inches. Then, last night, same problem, but parked against a curb. Try to push up hill, but no luck. Have to get towed to dealer again. Tow truck drops at dealer, and because I knew it would, I tried to start, and it worked. So any ideas? Dealer called me, says they can't get it to fail (again), but found one battery was "bad". I'm not really buying the battery story, but also understand the dealer having trouble figuring out what is wrong when nothing goes wrong for them. Tearing my hair out...
Could this be anything related to the anti-theft system? I know my truck will shut off if I try to take the shifter out of P while it's idling after being remote-started. Perhaps yours isn't registering that the truck is in P so it's not firing the starter?
Your gauges and accessories all popping on and the truck starting after you put it in N then back makes me wonder if somehow the theft system is getting involved.....
Thanks to all for the ideas so far. I will pick up the truck from dealer with new battery today, and we'll see. I'm skeptical about battery being cause since I've had luck multiple times putting truck in neutral, moving a few inches and then all fires up.
Ground could be issue. If something is loose somewhere, that could act like this.
Chuck- I too have thought about anti-theft. I've also thought about neutral-safety switch (assuming truck has something like this). If the NSS was thinking truck is not in park or neutral, and then I move shifter, move truck, and go back to park..could that cause this? That would explain the starter not rolling, but not sure if that explains lack of glow plugs and fuel pump.
Appreciate all the help. Will try to post a picture of my toy(s) soon.
Thanks.
Thanks.
Unfortunately I have NO idea how the anti-theft and any NSS we may or may not have work with each other, sorry. I'm completely shooting from the hip...
Just something about your symptoms makes me say something is preventing the starter signal, rather than that anything is broken and not able to. Have you tried shifting to N and starting it when it doesn't want to in P? In other words, before ever rolling the truck or returning to P.
Crystal
