Fan Speed Sensor , what to look for
Starting to do some towing of a trailer...
What criteria sets the fan speed boost to kick in?
EOT? ECT? or a combination of both?
At what temps does it kick into high gear (usually)?
Would it be noticeable?
I have a ScanGauge
Example: I was going up a very very long grade towing about 8000#
and the EOT got to about 225 and the ECT around 215
The ambient temp was around 70 degrees (yes, we dont get very cold around here)
would it have kicked in at that point? I din't hear and because of the traffic conditions I wasn't monitoring the FSS at the time on the ScanGague
Also.... what is the critical EOT when towing, what numbers would raise concern?
All comments appreciated
Alan from San Diego
I have a ScanGauge
Alan from San Diego
From the Tech folder here:https://www.ford-trucks.com/forums/3...ch-folder.html
Some say fan kicks on at 210, some say 215, others say 220. Full explanation: Engine temperature is not the only parameter that the PCM monitors to determine cooling fan operation. This is the reason that you will see some variation in engine temperature as it correlates to fan operation. The operation/description of the FSS (Fan Speed Sensor) from the PC/ED manual has a fairly good explanation as to how the system "thinks". This is not your traditional engine hits temp X and the fan clutch locks up. The fan speed sensor is a Hall-Effect sensor integral to the vistronic drive fan (VDF). The powertrain control module (PCM) will monitor sensor inputs and control the VDF speed based upon engine coolant temperature (ECT), transmission fluid temperature (TFT) and intake air temperature (IAT) requirements. When an increase in fan speed for vehicle cooling is requested, the PCM will monitor the FSS signal and output the required pulse width modulated (PWM) signal to a fluid port valve within the VDF. Engine begins to defuel at 221 deg. The thermostat begins to open at about 190*F to 195*F and is not fully open until about 215*F to 219*F..
Your temps sound ok to me. I would be watching pretty close at those numbers though, things can change pretty quick. I'm sure many people here would be more conservative but I'd be squirming at ECT of 220 and EOT of 235, and backing out of it at 225/245. I ran with a partially clogged oil cooler for most of a summer and settled on these #'s at that time. If I remember right I never saw ECT over 225 but EOT got close to 250 a couple of times on larger hills
After the EGR and oil cooler change my temps are much cooler I can pull hard and rarely go over 210 with oil temps 6-8 degrees higher at most.
