Power Steering leak fix and Gear Rebuild
Hello
I recently purchased a 77 f250, 2wheel drive. PO replaced the PS pump and both lines. Still leaking lots of fluid. My question: What level of difficulty is rebuilding it?
The steering is tight and true, so replacing seems to be a waste. I am an avid DIY’er, but also know when to stay away… is this something that is relatively easy to do with basic tools?
Very basic tools, since it is 2wd IMO its the best to remove the box and do it with it on the work bench.
Remove the pitman arm from the steering box output shaft (sector shaft), then there's a snap ring that needs to be removed. Once that's out of the way there is a washer, then a seal, then another washer and another seal.
Remove the first washer exposing the first seal. Take a sharp center punch and pierce the seal, screw in a sheet metal screw and pry the seal out. You can do two screws 180 degrees apart too.
Once the first seal is out, remove the second washer and repeat the process. if it is still installed and the lines are connected (you can also try just removing the snap ring, (after the pitman arm is off) turn the wheel to the left and start the engine, it will usually blow the whole thing out, both seals and spacers but you better have a huge drain tray under it, then reassemble.)
To replace the seals, apply a thin coating of grease to the inner lip of the seal and a thin coat of sealer to the outside diameter of the seal (I like No. 2 Permatex non-hardening). Slide the seal over the shaft and take a deep socket that’s just slightly smaller than the OD of the seal and drive the seal in until it seats. Replace the washer then the next seal, washer then snap ring. Reinstall the pitman arm, hook up the steering linkage and that's it.
If you don't have a socket that's deep enough you can use a piece of pipe or tubing too. The killer on these is getting everything centered. With the exception of the sector shaft Ford basically only sold the internals as an assembly.
The input shaft (F3AZ-3E502-A) & sector shaft (D7AZ-3E501-A) seal kits are available from Ford and auto parts stores.
Seal kit, steering gear sector shaft
Parts list #64, With gear ID SPA-AB, AJ, AN, BN, BS, BX, CC, CN
Basically this covers all 73-79 2WD F100-350 w/powersteering
D7AZ-3E501-A.. Sector Shaft Seal Kit
Last dealer cost $29.41 List $43.71
So try the dealership OR ……
Parts International, Farmers Branch, TX has 50 (972) 241-8730
Green Sales, Cincinnati, OH has 19 (800) 543-4959
Manderbach Ford, Temple, PA has 5 (610) 929-3683
Freese Motor Inc., Monticello, IA has 4 (319) 465-3541
Herb Chambers Ford, Westboro, MA has 2 (508) 366-8311
http://www.ford-trucks.com/forums/11...+steering+seal
Steering box input seal…piece of cake 30 minutes 78 F250. Try dealership OR……Autozone part # 8520 $8.99 in stock. Ford part # F3AZ-3E502-AInput Shaft Seal Kit…undo bolt at rag joint, remove plastic cover on steering column (in cab) loosen steering column bolts (2 bolts to dash) pull up on column and disconnect rag joint from steering box. Drill small hole in dust seal on steering box & screw a screw in and remove seal remove snap ring, drill hole in seal remove with screw. Replace seal, snap ring, dust seal and reconnect steering column.
EXTRA ADVICE: Remove the pitman arm. Remove the snap ring. Thread the nut back on just a couple of turns. Crank the engine, and turn the steering wheel from stop to stop, until the pump pressure pops the seals and spacers out. The nut keeps the seals and spacers on the shaft, in correct order and orientation.
Keep your old seals and spacers. Lay them out, in order, and oriented correctly, and then photograph them. You may need some of them. The kit can come with different thickness spacers, and might not be the same as the old ones. Fortunately, the spacers can be reused. The nut on pressure removal trick keep you from using a screw to remove both seals and possible save one."
The following 2 users liked this post by 77&79F250:
